      11-25-2020, 10:19 PM   #1211
KevinC
your average JAMF
KevinC's Avatar
'21 M2 Comp
'19 Golf R
Appreciate 7
Nate4641150.50
pyshin110.50
wdb4721.50
3798j11406.00
Dbaliko36.50
v3.2mc94.00
      11-26-2020, 07:32 AM   #1212
maupineda
Drives: E86 Z4MC
I have to say the Z4M is really beautiful... i like it more the more the time passes
      11-26-2020, 10:27 AM   #1213
pyshin
pyshin's Avatar
Drives: 97c2
empty parking lots early in the morning.. happy thanksgiving
wdb4721.50
3798j11406.00
      11-29-2020, 12:51 PM   #1214
JBuG12
JBuG12's Avatar
France
24
Drives: BMW Z4 2.5 (2006) PH 2
Only Z4 is good enought !
kaybat125.50
      12-01-2020, 05:29 AM   #1215
StigJ
StigJ's Avatar
Norway
333
Drives: '06 Z4 Coupe & '14 F30
Nate4641150.50
wdb4721.50
v3.2mc94.00
      12-04-2020, 01:22 PM   #1216
Monk_56
Drives: 2004 Z4
My Wrap project.
Decided to see if I could give my 04 a vinyl wrap.
wdb4721.50
      12-14-2020, 05:14 AM   #1217
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
The 3.0si has definitely earned my respect as a qualified race car. Took the car for its first race weekend with BMW CCA club racing at Roebling Road. The car performed like a champ, we still have a few things to work out, but overall very happy with the results
wdb4721.50
pyshin110.50
racerbruce3853.50
eggman51198.50
      12-14-2020, 09:41 AM   #1218
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
SO awesome.
For the unlearned, perhaps you can tell us about a few of the highlights of the HP class....safety rules (cage, seat, etc), engine, suspension.
Racerbruce
      12-14-2020, 04:42 PM   #1219
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Originally Posted by racerbruce View Post
SO awesome.
I have attached the CCA Club Racing Rules. All cars require a 6 point cage, safety etc. The key is the HP to Weight Ratio and the higher you go up the more modifications you can do. I built this car for WRL endurance series and BMW HP. the 3.0si you can get up to 285 to 295hp with a full set up, the key is the M3 with the S54 is in the same class but has to be almost 200lbs heavier. So HP/Weight becomes a bigger factor, as well as reliability. We still have a lot of tweaking to do but the car is a blast to drive. My other car which is be build for C-Mod has no weight restrictions and has a fully built S54 Stroker Motor. That will be a site to see. If you have any other questions feel free to DM me.
  • Spec (E30) (E36) (E46)
  • Sport Class
  • Prepared Class
  • Modified
  • Super Modified
SPORT AND PREPARED
A. Vehicles of the same engineering designation (for example, E36, E46),
type (for example, 325, 330, 318), configuration (for example, two-door,
four -door, all-wheel drive) and horsepower will be weight equalized to
the lowest of the model year factory weights.
B. Cars will be initially classified based upon published factory stock weight
(pounds) and published factory stock power (SAE bhp) using lbs./bhp
ratios as follows:
G = Under 10.00 lbs./bhp
H = 12.50 to 10.00
I = 12.50 to 13.99
J = 14.00 to 16.59
K = 16.60 to 18.99
L = 19.00 to 22.49
M = 22.50 and over
2. MODIFIED
A. Cars will be classified based upon actual engine displacement as
follows:
A = over 5000.000cc
B = 3499.001cc to 5000.000cc
C = 2980.001cc to 3499.000cc
D = 2199.001cc to 2980.000cc
E = 1800.001cc to 2199.000cc
F = under 1800.000cc
https://bmwccaclubracing.com/wp-cont...2020_v.6.1.pdf
pyshin110.50
racerbruce3853.50
      12-14-2020, 05:08 PM   #1220
racerbruce
racerbruce's Avatar
3854
Greetings M-Cast and thank you for the very detailed response.
If I'm reading this correctly, did you remove appx 150 lbs from the E86 (car 84) race car?? That alone must have really affected its handling, braking, turn, in, etc.
Just curious, what is the appx weight of the 6 point cage and how this weight added high in the car affected center of gravity, handling, etc.
What is the engine redline and what is the RPM that you upshift?? Perhaps they're two separate answers.
Really appreciate your correspondence....for those that only dream of a race car, this gives us insight into the real thing.
Racerbruce
      12-16-2020, 05:20 PM   #1221
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
We went with a different cage setup in this car than the CMod due to the weight restriction on a minimum prep weight is 2890. Prep weight includes fuel and driver weight. We should be able to get the car down to 2600 lbs dry with no problem. The balance of the car was really nice, but Tire selection will be important. I am switching to Hoozers and the 17" forged wheels. I ran both 17 and 18" with two different types of Toyo tires. I ran 2 seconds faster with the 17" and Toyo RR vs the 18" R888R.
Redline is revs are at 7200. Switching from the 3.46 to the 3.73 made a huge difference in the rev range.
racerbruce3853.50
      12-19-2020, 10:12 AM   #1222
racerbruce
racerbruce's Avatar
3854
Thank you -
You are amazing - such precision and so many "math equations" to calc to ensure the finished product meets spec/weight/etc....and gearing calcs to ensure proper rev and achieving maximum BHP....and the tires/wheels....wowie what a difference that can make.
Thank you for including us.
Racerbruce
      12-19-2020, 10:27 PM   #1223
Ducguy46
CLTMCarGuy
Drives: Z3M Roadster, Z4M Coupe, M3G80
What a thing of beauty!
racerbruce3853.50
      12-22-2020, 07:53 AM   #1224
c41250n
c41250n's Avatar
Hong Kong
30
Drives: BMW Z4M Coupe
here are some new pics!
Appreciate 9
v3.2mc94.00
pyshin110.50
Cyclops1473.00
W///7486.50
racerbruce3853.50
StigJ333.00
Ducguy46429.00
      12-22-2020, 11:16 PM   #1225
ANILE8
ANILE8's Avatar
No_Country
180
It's been a while.
pyshin110.50
3798j11406.00
racerbruce3853.50
      12-24-2020, 02:37 PM   #1226
Texaz3
Drives: Z3MC Z4MC E36M E46M E93M E39M
///Merry Christmas.
XMetal1131.00
racerbruce3853.50
      01-07-2021, 03:15 PM   #1227
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
First track day of the year
Appreciate 7
pyshin110.50
wdb4721.50
racerbruce3853.50
3798j11406.00
eggman51198.50
W///7486.50
      01-07-2021, 05:50 PM   #1228
racerbruce
racerbruce's Avatar
3854
Wowie!
YAY M-Cast!
SO great to start the year with this incredible black scalpel....
Racerbruce
      01-08-2021, 12:54 PM   #1229
F360C
Drives: E86 S54
Wow! I love the gold BBS LM's
07 Z4 M Coupe AW/IR
      01-18-2021, 06:56 PM   #1230
W///
W///'s Avatar
7487
Drives: F82GTS, E36/E92M3, Z4M
Took the car out on a nice long drive on the Blue Ridge Parkway after being parked for over a year (fresh rod bearings). I've missed this car so much
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
XMetal1131.00
wdb4721.50
pyshin110.50
      01-28-2021, 09:10 AM   #1231
F360C
Drives: E86 S54
Such a great pic!
The Blue Ridge is so amazing.. try to drive it once a year while stopping at all the cool other roads along the way to FL
07 Z4 M Coupe AW/IR
W///7486.50
      02-17-2021, 11:57 AM   #1232
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
The Z has such a timeless design. Some thinks the nose is too long, but I think it's perfectly proportioned!
pyshin110.50
3798j11406.00
Steeler2427.50
wdb4721.50
