11-03-2019, 07:43 PM | #1937 | |
Rep 1,692
He has a really good setup with everything inside of the truck and the two portable air jacks he has are straight dope. |
11-08-2019, 01:23 AM | #1939 | |
Rep 1,543
11-08-2019, 02:09 PM | #1940 |
Rep 154
New legs !
Out with the old : In with the new :
11-09-2019, 02:25 PM | #1942 |
E86 M Coupe
265
Rep 406
Brey krause/oem slider brackets, profi spg xl. Got more than ~inch clearence on the door panel
11-09-2019, 06:34 PM | #1943 |
Rep 12,569
did your stock seats have manual or power sliders?
11-10-2019, 10:55 AM | #1944 |
E86 M Coupe
265
Rep 406
Power seat sliders
11-24-2019, 06:34 PM | #1945 |
Rep 166
Well, bought a while back, but finally installed:
H&R front/rear sway bars (and made steel reinforcement plates for the front) slotted & cross drilled rotors all around ceramic brake pads all around oil change kit from ECS Lemforder FCABs Skyer convertible side covers Also, after many months of trying to track down the source of a 'clunk' coming from the front, I discovered the reinforcement plate that covers the oil pan had 7 of 8 bolts loose, and the 8th was missing! :O Everyone says to check the strut tower braces, but my issue was underneath. Can't wait to drive it this week! |
wdb4748.00 |
11-25-2019, 09:54 AM | #1947 |
Rep 12,569
I did those same 3 pieces (diff knob though) during summer.
Ordered some custom exhaust tips that fit over the stockers. Also bought new set of OEM motor mounts. |
11-25-2019, 10:10 AM | #1948 |
your average JAMF
3169
Rep 4,106
Everyone with the old BMW Assist panel on the console should ditch it for the oddments tray. BMW Assist as it was in 2006-2008 is no longer functional - it utilized the Verizon analog network, which has been shut down for years now. Might as well make use of the space with the tray, which is readily available and not expensive.
'21 M2 Comp
'19 Golf R |
11-25-2019, 10:31 AM | #1949 | |
Rep 376
This is the only shift knob I will now own. It's weighted and has a delrin cover (won't scorch your hand in the summer) that can be easily changed for different shapes. I bought one for my GT350 and put an (almost) identical one in the Z4M.
11-25-2019, 11:02 AM | #1950 |
Rep 779
I just bought a fuse kit also for dash cam. Which fuse # did you end up using ? is it the on with ignition ?
-Roranji
11-25-2019, 02:04 PM | #1954 |
Rep 376
More comfortable than it looks. I just picked it up a few months back and have not taken it to the track. Currently I drive it on the street (although the seats are quite hot without AC during the summer months).
11-25-2019, 02:44 PM | #1955 |
Rep 912
Do you have more info on those? How is fitment to the car and to the passenger?
11-25-2019, 02:57 PM | #1956 | |
Rep 376
I believe these are the seats. |
3GFX722.50 |
11-26-2019, 03:47 AM | #1957 |
Rep 506
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
My Recaro Pole Position Seats
11-27-2019, 08:05 PM | #1958 |
Rep 12,569
"Shorty" OEM valve stems... factory originals are 56mm but replacing with 43mm (p/n 36146792829 for anyone wondering)
