05-20-2021, 09:03 AM | #221 |
10834
Rep 4,890
What do you mean it's the whole thing?
They are going to change specific rules. This is a matter of which rule, which paragraph they're going to adapt. That they've divided moving and flexing in 2 different sections says that it's not as simple as your 'basic definitions'. The FIA makes a distinction between these 2 concepts. If it was a matter of 'basic definitions', the FIA rulebook was only comprised of 'basic definitions'... But we'll see in a few months if you're right and the adaptation will be in section 3.8 or if I'm right and the adaptation will be in section 3.9 It will be interesting to reflect on this when it finally happens
05-20-2021, 09:34 AM | #222 |
Rep 4,381
I would imagine that the FIA will change the regulations only to the Aerodynamic Component Flexibility section with new numbers for the load/deflection tests.
For instance increasing the load number in this section (and other related) "Rear Wing Flap Pullback The uppermost aerofoil element lying behind the rear wheel centre line may deflect no more than 7mm horizontally when a 500N load is applied horizontally. The load will be applied 900mm above the reference plane at three separate points which lie on the car centre plane and 270mm either side of it. The loads will be applied in a rearward direction using a suitable 25mm wide adaptor which must be supplied by the relevant team." |
05-20-2021, 09:42 AM | #223 | |
Rep 24,655
Merc's DAS was approved and allowed by the FIA the entire '20 season . Mercedes had the whole '20 season in 17 races huge advantage by DAS ! Only after the 17 races in '2020 when the season was completed, DAS was (finally) banned by the FIA . Situation 2 : "FIA taking actions on Red Bulls '2021 flexible rear wing" Within 2-3 weeks the FIA has to change the 2021 wing regulations and new tests will be performed ! If this is going to happen so suddenly in a hurry ... The FIA is financially sponsored by Mercedes !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick60000.00 |
05-20-2021, 11:01 AM | #224 | |
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
The Ferrari Fuel Trick passed the test. That didn't make the car compliant within the rules structure governing fuel flow because they found a way to defeat the test. Just because the engineering department found a clever way to beat the test, doesn't make the car compliant. It's really simple. There is a storm brewing with the affected teams thinking of performing a protest for the upcoming race in the vein that the, "bendy wing" will confer a huge advantage in Baku because of the length of the straight.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
05-20-2021, 11:58 AM | #225 | |
10834
Rep 4,890
The way the FIA talks about parts moving in 3.8 are parts that on their own can be set in different positions ('the freedom to' is how they describe it). The parts that they exclude in this paragraph are also parts that can be set in different positions: mirrors and air ducts on the wheels (wheels can turn and go up and down). That 3.9 is a very long section that contains rules for the amount of flexing of all the different bodyparts says to me that the FIA distinguishes between parts that can 'move' (as in moved and set in different positions) and parts that flex under differernt circumstances. I suspect that they'll change 3.9.6 in both the amount of force, the direction of the force and the place of the force as test specs to a certain amount of flexing. As this article specifically sets the rules for how much a rear wing may flex. I can't imagine the RB car (and maybe other car with flexing wings) not meeting this current article. Because the FIA said that no current cars fail to meet the rulebook on this point. So there is no cheating, no breaking of rules. MErcedes (and apparantly mclaren, and maybe other teams) want the rules and ways of testing to be more stringent on this aspect. And the FIA is going to follow those suggestions. So my guess is that in 6 months time we'll see RB cars with stiff wings and a very flappy rear finn
05-20-2021, 12:04 PM | #226 |
Rep 2,126
I think Nico Rosberg winning the championship proved that the way you can beat the best is to mess with their head.
All of these drivers and teams are the peak of their respective game, so it only makes sense for the top teams to start a little FIA and media war to distract the other party from the job at hand a bit and gain that one messy pit stop, or divert resources to investigate something that has no benefit and end up losing a race or two by a bad call or simply a 0.001 in qualifying. |
05-20-2021, 12:38 PM | #228 |
Rep 24,655
That's for you mate . Binotto spoke at this time !
I really wonder who hasn't a flexible rear wing ?
Killed by Death12414.50 |
05-20-2021, 12:48 PM | #229 |
Rep 3,516
///M Power-Belgium63307.00 GuidoK10833.50 |
05-20-2021, 03:28 PM | #230 | |
Rep 24,655
M5Rick60000.00 |
05-20-2021, 03:54 PM | #231 |
Rep 19,522
///M Power-Belgium63307.00 |
05-20-2021, 10:44 PM | #232 |
10834
Rep 4,890
Interesting video.
But what I don't understand is regarding to the potential new FIA rules. They say that (@5:10) following the new loads applied (1000N vertically and 2x 750N horizontally directed to the rear), the rear wing is allowed to flex 1 degree. So that is a rotational deformation. The video only refers to 3.9.3 (@2:58) and not to 3.9.6 which covers amount of flex (in mm, not degrees) when applied with horizontal load (on the top aerofoil). I would expect the FIA to expand 3.9.6 with a vertical load and an allowable deformation in mm (they can also write that in 3.9.3 of course, but the point is an allowable deformation in mm, not in degrees.) Is Mercedes' problem with the RB wing that it rotates too much (so the direction of the aerofoil is changed) or that it sags too much, so that it might catch less airstream as it hides more behind the rest of the car? If the last case is the problem, setting limits to the rotational deformation has no effect. It's not impossible to design a rigid spring that only deflects in one direction, so that any rotational movement is limited but linear movement is allowed (in my eyes that's what they already did). So does the video miss the real problem and corresponding FIA article at hand or don't I understand the problem correctly?
05-21-2021, 02:00 AM | #233 |
Rep 19,522
[QUOTE=GuidoK;27612530]Interesting video.
But what I don't understand is regarding to the potential new FIA rules. They say that (@5:10) following the new loads applied (1000N vertically and 2x allowable deformation in mm, not in degrees.) Is Mercedes' problem with the RB wing that it rotates too much (so the direction of the aerofoil is changed) or that it sags too much, so that it might catch less airstream as it hides more behind the rest of the car? ----------------------------------- *This. It could be that Merc have got their knickers in a twist (pun intended). |
Killed by Death12414.50 ///M Power-Belgium63307.00 |
05-21-2021, 04:53 AM | #234 |
i'm just saying
5725
Rep 2,634
FIA admits flexi wings are giving advantage and McLaren may go for protest..
https://www.motorsport.com/f1/news/h...hreat/6512421/ ..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
MKSixer34184.50 |
05-21-2021, 05:04 AM | #235 |
Rep 19,522
I wasn't joking about the cost.
https://www.motorsport.com/f1/news/a...-joke/6512286/ |
05-21-2021, 08:01 AM | #236 | |
Rep 3,516
Article 3.9.9 at 4:36 screwed my argument the FIA shouldn't change the test mid-season |
MKSixer34184.50 |
05-21-2021, 08:27 AM | #237 | |
Rep 11,637
This is a problem. Everyone thinks the test is the focus when the actual issue is non-compliance with the rules regarding flexible wings. Defeating a test doesn't mean compliance with the rules. Why is this sooooooo difficult to understand? If I figured out a way to break into a bank without a trace and removed money, did I break the law even though there is no evidence but my possession of the money? Of course I broke the law. The wings comply with the test but, in situ, flex which is against the rules. Easy peezy, lemon squeezy.
05-21-2021, 08:32 AM | #238 |
Rep 19,522
RB boss has now accused Wolff of having an illegal FRONT wing on the W12..looks like the details on that one will be spilled out soon but I gather it concerns the endings.
05-21-2021, 08:39 AM | #239 | |
Rep 11,637
Those who live in glass houses shouldn't throw stones. This isn't the first time RBR has been caught cheating now they are saying, "But, but, but.....waaaaaaaaaaaaaaaa Mercedes...waaaaaaaaaaaaaaaaaa." How sad is it that a team has the alleged best driver to ever hold a steering wheel, an illegal car, and still can't win? As one of the worst leaders I ever worked for said, "If you can't win by cheating, you don't deserve to win." This should be the moniker hung around RBRs neck.
05-21-2021, 08:58 AM | #240 | |
Rep 3,516
///M Power-Belgium63307.00 M5Rick60000.00 |
05-21-2021, 09:05 AM | #241 | |
Rep 24,655
05-21-2021, 09:14 AM | #242 |
Rep 19,522
