12-19-2017, 10:53 AM | #1 |
Rep 453
Drives: 2007 Z4M Coupe
Sway bar endlinks aftermarket vs OEM
It's time to change mine out. I have a small clunking noise from the front so hopefully this fixes it. My question is, should i get OEM or an aftermarket? I'm not looking to track my car so keep that in mind. Wasn't sure if there was a significant difference in quality between the two . There are several aftermarket options in ECS that I'm considering. What's everyone else's experience?
12-19-2017, 01:13 PM | #2 |
Rep 2,705
I have the Hotchkis adjustable links on mine. Didn't really need the adjustability but the price was hard to pass up.
Very stout pieces. Been on for 4 years now with zero issues.
12-19-2017, 03:01 PM | #3 |
Rep 758
JMHO, but if you're not going to track the car, do autocross, and any other activity where fine tuning the handling would make a difference, then you don't really need the adjustability. A good set of OEM end links from ECS or FCP Euro should do fine.
Top Down 365
12-25-2017, 10:14 AM | #4 |
Rep 453
Thanks gents. I forgot to mention that I'm lowered about 1.5" on H&R coilovers. Right now I'm running stock end links. Is my drop enough to cause preload on the sway bar? I'm reading a "mild" drop shouldn't make a difference but I'm not sure what the definition of mild is.
12-25-2017, 11:59 AM | #5 |
Rep 11,667
Drop has nothing to do with pre-load.
The mounting tab is below the lower spring perch. +1 from FCP Euro. Big benefit from FCP euro is they cover you for free replacements for as long as you own the car.
12-26-2017, 12:24 PM | #6 | |
Rep 1,923
I only adjust my endlink when I change the sway bar setting.
coh661191.00 |
