Go Back   ZPOST > Marketplace > Sponsors Classifieds
      10-02-2014, 12:19 PM   #1
ApexRaceParts
Drives: M3
► APEX |Redesigned and Reinforced Wheel Studs
It's A Good Time To Upgrade Your Studs
Redesigned APEX wheel studs feature an improved shoulder design to reduce stress risers and stud failure. 75mm and 90mm versions are available with a true bullet-nose race tip for faster wheel installs and a cleaner look, or with an easy to install hex head.
What's New?
The Bullet Nose
Don't compromise on safety and quality to get the stud style you want. Most affordable wheel studs today only offer a hex head version. Saving a few minutes during the install is great, but most racers want a true bullet nose tip. We've brought back the bullet nose design and give you the option to pick your preference at no added cost.
The Beefy Shoulder
Typical wheel studs have no shoulder to seat with the hub. Those studs are cheaper and easier to produce, but can result in new threads being cut into the stud as they are tightened. APEX's new wheels studs were engineered with a beefy, tapered shoulder design, allowing for a consistent and flat surface to secure to the hub. This feature helps eliminate stress risers that can lead to stud failure in most other designs. This feature helps eliminate stress risers that can lead to stud failure in most other designs, and will serve as a visual indicator that your studs have been properly secured during the installation process.
Lug Nuts Included
No need to order hardware separately. All studs are finished in black, and lug nuts are available in either a black or silver finish.
Studs vs. Standard Bolts
Less Wear
Wheel studs replace your OEM lug bolts by simply threading into your car's hub. Once installed they do not need to be removed when changing or removing wheels, which preserves the threads on your car's hubs. They also guarantee proper thread engagement, as you can see how many threads were engaged during install.
Less Time
No more time spent trying to line up lug holes while holding wheels up with your feet. Studs make it easy to slide the wheel on and leave it there while grabbing the hardware. Lug nuts easily slide on and off the end of the stud, and can be started by hand with little-to-no effort.
Use Any Spacer
All spacers require extended-length hardware to be used safely. With our extended-length studs, you are no longer required to buy a bucket full of various-length bolts for use with different size spacers. Our 75mm studs support up to 12mm spacers, and our 90mm studs support up to 25mm spacers.
Available Sizes & Options
75mm 5-Lug Stud Kits (20 Studs and 20 Lug Nuts) - Supports Up To 12mm Spacers
75mm M12 BMW 5-Lug Kit with Hex Head - Black Lug Nuts
75mm M12 BMW 5-Lug Kit with Hex Head - Silver Lug Nuts
75mm M14 BMW 5-Lug Kit with Hex Head - Black Lug Nuts
75mm M14 BMW 5-Lug Kit with Hex Head - Silver Lug Nuts
75mm M12 BMW 5-Lug Kit with Bullet Nose - Black Lug Nuts
75mm M12 BMW 5-Lug Kit with Bullet Nose -Silver Lug Nuts
90mm 5-Lug Stud Kits (20 Studs and 20 Lug Nuts) - Supports Up To 25mm Spacers
90mm M12 BMW 5-Lug Kit with Hex Head - Black Lug Nuts
90mm M12 BMW 5-Lug Kit with Hex Head - Silver Lug Nuts
90mm M14 BMW 5-Lug Kit with Hex Head - Black Lug Nuts
90mm M14 BMW 5-Lug Kit with Hex Head - Silver Lug Nuts
90mm M12 BMW 5-Lug Kit with Bullet Nose - Black Lug Nuts
90mm M12 BMW 5-Lug Kit with Bullet Nose - Silver Lug Nuts
Photos
Ordering and Contact Information
  • Hours: Monday - Friday, 9AM to 6PM PST
  • Shipping: All orders are shipped directly from us via UPS. Local pickup also available at our Livermore, CA Warehouse. (Map It)
      06-18-2015, 12:16 PM   #2
ApexRaceParts
Drives: M3
For those of you wondering how to install one of our Bullet Nose stud kits, we filmed this video showing you our process.
      07-02-2015, 07:11 PM   #3
ApexRaceParts
Drives: M3
For those of you with a Hex Head stud kit, this video will show you just how to install your stud kit.
      08-06-2015, 06:52 PM   #4
ApexRaceParts
Drives: M3
For any questions feel free to contact us!
      08-09-2016, 04:41 PM   #5
ApexRaceParts
Drives: M3
For any questions on just how tough our studs are, shoot us a PM or email us today!
      11-14-2016, 06:09 PM   #6
Expert@ApexRaceParts
Expert@ApexRaceParts's Avatar
872
Drives: M3
For any questions feel free to call or send us an email!
      12-12-2016, 04:01 PM   #7
872
Drives: M3
We have stud conversion kits available in both the 90mm and 75mm lengths. Feel free to contact us via phone or email with any questions!
      07-25-2017, 12:13 PM   #8
872
Drives: M3
Give us a call or email to order, or if you have any questions regarding fitment, spacers, or clearances.
      05-06-2019, 06:25 PM   #9
872
Drives: M3
Quick, easy installation and everyday benefits make these studs a must.
      Today, 03:38 PM   #10
872
Drives: M3
Questions about the benefits of using studs vs. regular bolts? Give us a call or PM and we'll get you the info you need.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
