Go Back   ZPOST > Marketplace > Sponsors Classifieds
      10-04-2017, 12:44 PM   #67
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Hi all - Providing some stats on my square setup as I have been asked a couple of times for more information. PM me if more info is needed and hope this helps!
Wheels: APEX Arc-8 18x9.5 et35
Tires: Toyo Proxes R888R 265/35/18 (these run big - more like a 275)
Suspension: TcKline DA Coilovers
Spacers: Front None | Rear 12mm
Camber: F: -2.8 (Camber Plates) | R: -2.0
Toe: F: 0 | R: 1/8 Total
Caster: Maxed Out
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      10-04-2017, 02:14 PM   #68
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Caster: Maxed Out
Gorgeous!
Thanks for providing your fitment info, do you mind if we share your photos and specs with other Z4 customers looking for advice?
      10-04-2017, 02:51 PM   #69
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Originally Posted by ApexRaceParts View Post
Gorgeous!
Thank you and absolutely, you're more than welcome to!
      10-09-2017, 12:19 PM   #70
Expert@ApexWheels
Expert@ApexWheels's Avatar
3525
Drives: M3
Great, much appreciated!
      10-30-2017, 04:21 AM   #71
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
Mine's a Z4M coupe with stoptech 6/4 BBK and H&R coilovers. Can a staggered setup of 18x9.5 et35 / 18x10 et25 clear the calipers?
      10-30-2017, 02:46 PM   #72
Expert@ApexWheels
3525
Drives: M3
Thanks for the post! The 18x9.5" ET35 ARC-8 will clear the 6-piston 355mm kit with a 5mm spacer up front. We haven't confirmed fitment on the 380mm kit, but we are happy to test it if you can provide a brake template.
Hope this helps!
      10-31-2017, 05:41 AM   #73
pcube
pcube's Avatar
58
Thanks for the reply. Mine is the 380mm kit. What does a brake template look like, and how do I get one?
Do you know of any ARC-8 specifications that will definitely clear my bbk? Perhaps in 19", which is the size I'm currently running on.
Hope this helps!
      10-31-2017, 01:48 PM   #74
Expert@ApexWheels
3525
Drives: M3
Brake templates are paper cutouts provided by the brake kit manufacturer and are used for test-fitting purposes. They can typically be found on your kit's product page on the manufacturer's website.
The 19" will require the same spacer, since the clearance issue is with the spokes, rather than the barrel.
Hope this helps, let me know if you have any additional questions!
      11-03-2017, 08:41 AM   #75
pcube
pcube's Avatar
58
Is this it?
      11-20-2017, 03:18 PM   #76
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Is this it?
It sure is! That kit will clear the following ARC-8 sizes:
18x9.5" ET22
18x10" ET25
18x10.5" ET27
All 19" sizes
The 18x9.5" ET35 ARC-8 would require at least a 12mm spacer to clear, making it an effective ET23, in which case you would just use the 18x9.5" ET22.
Our 18x9.5" ET35 EC-7 wheel will clear the 6-piston 380mm StopTech kit with no issues, however.
      11-21-2017, 08:10 AM   #77
pcube
pcube's Avatar
58
18x9.5" ET22
18x10" ET25
18x10.5" ET27
All 19" sizes
Thanks for the update
      12-11-2017, 02:38 PM   #78
Expert@ApexWheels
3525
Drives: M3
TIRES NOW AVAILABLE
  • Michelin Pilot Super Sport
  • Michelin Pilot Sport 4S
  • BF Goodrich g-Force Rival S
  • BF Goodrich g-Force Rival S 1.5
  • BF Goodrich g-Force R1S
View Complete Tire Selection
Add tires to your ARC-8 wheels with free in-house professional mounting, balancing, and quality control inspection. Check out our tire selection and feel free to contact us for a recommendation.
      05-17-2018, 04:33 PM   #79
Expert@ApexWheels
3525
Drives: M3
Now available due to popular demand, red APEX centercaps! Use this link to check them out and place a pre-order.
      07-31-2018, 10:06 PM   #80
winnipegz4m
Drives: 2007 Z4M Coupe
ApexRaceParts
Still recommend the following for stock fitments? (Concave F&R)
18" Staggered:
F: 18x8.5" ET38 (Profile 1) - 235/40-18
R: 18x9.5 et22 (Profile 3) - 265/35-18 or 275/35-18
Any experience fitting these over bilstein B12 setups - that's bilstein dampers paired w/ Eibach prokits.
Edit - I'm talking "stock fitment" being no camber plates, spacers, etc.
Cheers!
      08-01-2018, 02:49 PM   #81
Expert@ApexWheels
3525
Drives: M3
Originally Posted by winnipegz4m View Post
ApexRaceParts
18" Staggered:
Cheers!
Thanks for the post! That is indeed our recommend "OEM+" fitment for the Z4M. No spacers or additional modifications will be required with the B12 suspension.
      08-02-2018, 09:37 PM   #82
winnipegz4m
Perfect - cheers!
For Canadian orders - should I order through ApexRaceParts.com, or do you have a Canadian dealer that you can recommend that carries inventory?
      08-03-2018, 12:42 PM   #83
Expert@ApexWheels
3525
Drives: M3
Perfect - cheers!
winnipegz4M,
Thank you for reaching out, we do not have any stocking dealers in Canada at this time. We would recommend purchasing directly through our website. Feel free to PM us if you have any additional questions!
Best,
Max
      08-15-2018, 04:19 PM   #84
Jag10
Drives: Jaguar XKR
Any sales coming up for Labor Day?
Thanks
      08-28-2018, 01:56 PM   #85
Expert@ApexWheels
3525
Drives: M3
Thanks
We do have some Group Buys running at the moment, including a deal on 17" ARC-8 wheels. You can view all our current group buys here: https://www.gangup.com/apex
      09-16-2018, 10:56 AM   #86
winnipegz4m
Expert@ApexRaceParts - bonus questions - is there a 19 inch ARC 8 setup that fits w/ stock suspension - i.e.: without camber plats, spacers, etc.? Just debating 18 vs 19...
      09-17-2018, 01:26 PM   #87
Expert@ApexWheels
3525
Drives: M3
Thanks for the post! For a 19" ARC-8 fitment, we recommend the following:
Front: 19x8.5" ET35 with 235/35-19 tires
Rear: 19x9.5" ET22 with 275/30-19 tires
- Direct fit with no spacers or modifications required
This fitment is also available in 18" as well:
Front: 18x8.5" ET35 with 235/40-18 tires
Rear: 18x9.5" ET22 with 275/35-18 tires
Let me know if you have any other questions!
      11-07-2018, 12:19 PM   #88
Expert@ApexWheels
3525
Drives: M3
Strong, light, affordable. Choose three.
