01-29-2009, 05:19 PM | #23 |
Fapmin
402
Rep 2,660
01-29-2009, 05:31 PM | #24 |
Rep 516
01-29-2009, 05:34 PM | #25 |
Rep 116
01-29-2009, 05:40 PM | #26 |
Rep 3,668
01-29-2009, 06:23 PM | #28 |
Rep 2,548
01-29-2009, 06:38 PM | #29 | |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
I think that compound lifts help to strengthen your core the most (ie. squats), but for additional ab work I like to do weighted excercises as well. I switch between targeting upper and lower abs every few days. For upper abs I like to do weighted crunches on the floor with my legs in the air, and for lower abs I like to use a decline bench with a weight on my chest. One thing to keep in mind though, which is something that took me a long ass time to figure out, is that most people who do marathon ab work and never see results is usually because they don't have a proper diet, and also they don't train their abs correctly because they think that the abdominals work like a hinge like most other muscle groups. This is incorrect as if you do crunches, or any other ab excercise for that matter, like a hinge you are working your hip flexers instead of your abs. You have to work them like an accordian (sp?) where you really focus on contracting them as much as possible during the excercise, and that makes all the difference IMO. **edit** I just saw your pic posted so your not a noobie when it comes to working out. I would say that if you cut for two months you would have great ab definition, but if you don't like being "tiny," which I don't think you would be at 10lbs or so less, then you can just focus now on putting on mass and then cut for abs later on. Its hard to do both at the same time though unless you already have a low enough bf%.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
01-29-2009, 06:39 PM | #30 |
Moderator
132
Rep 6,775
I just bought a caliper for like 15 bucks... its close enough because the delta is what I'm really interested in seeing anyway. The scales that measure BF that I have tried all suck balls.
-Michael.
01-29-2009, 11:17 PM | #32 |
Rep 2,548
I used the stand to do leg lifts. Another way I used to make my friends do with me is have one guy stand in front of you with their hands out a little bit above your waist level. While you lift your leg, you'll try to touch his hand. When you're almost touching the hand the guy with the hands out with push your feet down at the same time. Hold your leg out for 3 sec then drop it down. I usually do 15 reps of these.
