      06-11-2019, 08:35 PM   #1
Z4M06
Drives: 2006 black Z4 M
Factory brake duct block off plate
I decided to remove the the factory brake duct because they were loose and falling apart. I started noticing some fender liner rubbing when going over 60 mph. I figure there's to much pressure build up in the fender push the liner against the front tires. So I ordered a piece of 6"x30" carbon fiber penal from eBay and made these block off plate. $60 for the carbon fiber penal and a couple black rivets.
longress102.50
Mirko166.50
      06-12-2019, 08:39 AM   #2
longress
longress's Avatar
Drives: 2007 Z4M Coupe
Outstanding job!
I tried to cover mine with poly but I had a heck of a time trying to figure out the angles.
      06-15-2019, 06:33 PM   #3
Z4M06
I used a 1/4" packaging foam board that came with the carbon fiber penal to a make a template. It took about 3 try for me to get it to the shape i wanted. The foam board is very easy to handle, I just scrape it on my concrete drive way to Shape the corner and curb. If I have to do it again I would use a thinner pierce of carbon fiber. The one I got was 3/32 thick it's a little hard to flex.
longress102.50
      06-15-2019, 07:34 PM   #4
Azeka1
Track Junkie
Azeka1's Avatar
Albania
235
Drives: E86 M Coupe
Great job! I've been thinking to do the same and appreciate the motivation.
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | SS Headers | Rouge Exhaust| APEX ARC-8 | APR Aero | Sparco Seats/Belts | Weichers Cage | Solid Motor/Trans/Shifter/SubFrame | Poly Bushings | Race Camber Plates/Arms | CSF Rad/Oil | BW Brake Ducts | Braille Battery | AC/EGR Delete | 3,100lbs
1991 SW20 MR2 Turbo | Widebody | 400WHP/355TRQ | 2017 Audi Q7 | 2010 VW CC 2.0T
Gone: 2014 Audi A6 | 2011 G37 S Coupe 6MT | 2004 G35 Coupe
      06-30-2019, 09:13 AM   #5
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1049
Drives: 2007 Z4MC
Nice job. Bet that helps the aero.
      09-19-2019, 08:31 PM   #6
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
2011 335i Coupe  [0.00]
thats a good idea. that duct work is kind of a mess anyway.(1/2 baked design)
pulling the nose to do that would be easy.
Ken SCCA/BMWCCA
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
