10-24-2021, 01:37 PM | #1 |
1999 E46, 2002 E53, 2007 E85....all in progress
Rep 103
Need help with radiator hose issue.....
Hello Z4 fans, Today I was changing my OFH gasket on my 2007 3.0 Si but when I removed the radiator hose off of the OFH unit an Oring and
a small plastic ring came out and I did not see how they came out. Any chance anyone knows how they go back in? The pic below with the yellow highlight shows where I'm talking about. The Oring seems almost to big to fit inside the hose connector but there was no leak before removal. -
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... Last edited by CrazyOneToo; 10-24-2021 at 01:56 PM.. |
10-27-2021, 01:30 PM | #2 |
Rep 1,107
I changed both my upper and lower radiator hoses two months ago so this is from memory. I think the O-ring goes on the radiator fitting and the plastic (rubber?) ring goes inside the fitting on the end of the hose. If you want to confirm, take the other end of the hose off from the radiator (taking care not to dislodge the same two rings) and see how those are fit.
Also, if those are your original hoses you may want to think about replacing them (as well as the coolant reservoir). BMW cooling system plastics are known to have a working life of roughly 10 years. One overheat encounter can warp your head and then you've got a German flower planter. Edit: Just looked at your sig and see you own 3 of Munich's finest...never mind. Last edited by elerner61; 10-27-2021 at 02:36 PM.. |
10-27-2021, 03:39 PM | #3 | |
Rep 2,704
10-28-2021, 11:52 AM | #4 | |
Rep 103
I see no way of getting the oring back in there without it being bunched up. I assume it was placed inside there originally by a machine that compacts it to insert it. I bought another hose anyway. Didnt want to chance an overheating situation. Thanks
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... |
10-28-2021, 11:54 AM | #5 |
Rep 103
Thanks. I removed mine from the radiator and see no way to reinstall it properly enough that I wouldnt worry about it going bad while driving.
12-27-2021, 03:06 PM | #7 |
Rep 103
Yes, they have a clip ring that pops up then they pull straight off.
12-31-2021, 09:25 AM | #8 | |
Rep 18,717
dbarton62 posted a good pic of what the connectors look like from the inside, look at them closely and notice the indexing slots. After a few years of service, the connectors get stuck in place on the radiator hose bibs. The connectors are indexed to the bibs, which means you can't twist the connectors to break the friction that develops between the two parts. All you can do is wiggle the connectors up and down and left and right to try and break the friction. That doesn't work sometimes. Others have sprayed penetrating oil into the connectors to assist in chemically breaking the friction. That seems to work on occasion. I've not tried that method personally, but if your hoses are stubborn to remove it can't hurt to try. So as CrazyOneToo explained already, the female side of the connector has a spring clip that pulls up to an open position (you don't have to fully remove it). Just use a flat-blade screwdriver to lift it from its locked (down) position. Once the spring clip is unlocked, then wiggle the female side (hose side) of the connector up and down and left and right to break it loose as you pull it away from the radiator. Do not try and rotate the female connector on the bib because you'll just break the indexing tabs on the bib (male) side of the connection. If you do that, then a new radiator is in order. Hope this helps.
01-03-2022, 04:42 PM | #9 |
Rep 1,107
Some patience may be required. My upper hose came right off but the lower one was very stubborn. It required quite a lot of wiggling, pulling and conniving before it yanked free.
