      07-31-2018, 10:46 PM   #1
2272
Supersprint Section 1 + Rogue Section 2 Combo?
Anyone here running factory exhaust (headers and mufflers) but swap out section 1 and 2 for Supersprint S and Rouge’s X pipe?
Also is it safe to assume all of the above would bolt up, including X pipe to OEM mufflers?
How loud would this setup be? Any noticeable drone or rasp?
      08-01-2018, 12:36 AM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Originally Posted by 3002 tii View Post
Anyone here running factory exhaust (headers and mufflers) but swap out section 1 and 2 for Supersprint S and Rouge's X pipe?
The stock silencers are still quiet with catless headers, not much more than stock.
See the Exhaust Fest results. You should be able to get some reasonable comparisons there. https://www.zpost.com/forums/showthr...8#post11811418
      08-01-2018, 12:47 AM   #3
RossBMWZseries
Rogue’s X pipe is basic bolt on to OEM mufflers. As for the SS section 1 (S pipe), the X pipe will bolt on to it but I’m not sure if the S pipe is bolt on to the OE headers. Based on a quick google pic search, there’s catless SS S pipes that are bolt on, some other SS S pipe options may need welding to the OE headers
      08-01-2018, 06:31 AM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
SS V1 section 1 would need to be welded and modified, but V2 should replace the OEM s-pipe. I don't have firsthand experience with the V2.
      08-01-2018, 08:24 AM   #5
2272
Correct there’s 2 versions of the S pipe
I believe this one fits SS headers
https://www.turnermotorsport.com/e/p...straight-pipe/
And this one bolts up to oe headers
So in theory it seems oe headers -> SS section 1 -> RE x pipe -> oe mufflers should work but confirmation would be great. I know the oe headers with stock everything else isn’t terribly loud but I think the rasp would be more noticeable for vert owners
      08-01-2018, 10:58 AM   #6
RossBMWZseries
If you're willing to weld the OE headers onto the SS section 1, then yes this should work (OE headers>SS S pipe>RE X pipe>OE mufflers.
Everything is more noticeable for the vert owners, but damn it if you're anything like me, you're gonna love it
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
      08-02-2018, 11:46 AM   #7
F360C
Drives: E86 S54
RE used to make a section 1 for our cars in addition to the xpipe. I have a set but dont use them much because combined with my SS section 2 and SS race mufflers its too loud. But it does shoot flames which is cool!
07 Z4 M Coupe AW/IR
      08-02-2018, 09:51 PM   #8
2272
If you ever want to sell the RE section 1 let me know
      08-03-2018, 08:05 AM   #9
Azeka1
Azeka1's Avatar
285
Drives: E86 M Coupe
Yup, everything will bolt up - no welding needed. The "SS Section 1 Straight Pipe" (789812KT) that you referenced above will bolt up to OE headers AND SS Non-Stepped Headers "Tubolare V1".
Currently Running the following which is pretty much what you're looking to do but with the headers & section 1 swapped:
SS Non-Stepped "Tubolare V1" Headers -> OEM Section 1 -> RE X-Pipe -> RE Exhaust
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      08-03-2018, 10:30 AM   #10
RossBMWZseries
Is the RE section 1 catless?
      08-04-2018, 01:58 PM   #11
Vanne
Vanne's Avatar
United Arab Emirates
1593
Drives: 2007 Z4MC
hmm, i might be running what your asking.
CSL headers (euro Z4m) to SS catless section 1 to RE Xpipe to a set of race mufflers.
RE Xpipe def bolts up to oem mufflers, as mine bolted up to the OEM pipe before the swap, does the SS s1 bolt up to your USA headers? beats the hell out of me, but i would probably think so..
Nfi about your mufflers , but yeah its pretty loud. and disturbingly so if your not in the right band.
Powered by
      08-06-2018, 06:40 PM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
Yeppers.
Fit is a little sketchy, but I think all of the aftermarket ones are.
They make the bend toward the tunnel too soon after the headers, which runs them across part of the trans mount.
