      08-22-2010, 12:46 PM   #1
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Better wheel pics - opinions on fronts?
Just to reiterate specs - fronts are 18x9 et38 w/ 255/40 tire
RAC Monolites RG63
The fronts are my main concern. The damned perfectionist that I am, I'm thinking the fronts are set out about 5-8 mm too far, but honestly I'm undecided at this point. Any and all opinions are appreciated. If you've read my other thread in Wheels&Tires, I do have a rubbing issue up front and I was hoping to put Dinan springs on that I sourced used. Not married to these wheels so, as much as I'd hate to let them go, the grass may be greener.....from the very beginning, I knew I was putting a boutique wheel specially designed for the E46 M3 on a Z4M and I was always worried fitment wouldn't be a perfect as I wanted it.
See what you think guys and gals - really, I'm all ears for comments or suggestions. Thanks!
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      08-22-2010, 01:47 PM   #2
Rated M
Drives: 2007 IB Z4MC
Get some suspension and some camber plates for up front.. Dial in a little neg camber and that will be what all of us call "HELLAFLUSH"
Keep those wheels man, I think you'll be very happy with the look after a drop...
      08-22-2010, 02:09 PM   #3
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
stock, they do stick out 5mm too far. If you're gonna lower her either way, do it, and then make the decision to keep or sell
      08-22-2010, 02:32 PM   #4
OG_M3
Drives: ae86; z4mc
2011 BMW M3  [0.00]
2007 BMW Z4MC  [0.00]
1985 AE86  [0.00]
imho front tires look a little too "fat"- which is probably the source of your problem. a 245/40 or 255/35 will alleviate the problem.
offsets are good, and i have seen 19x9 35 on the car before with no rubbing issues. also seen as low as 19x9+22 with 255/30's on a local z4m as well.
      08-22-2010, 08:23 PM   #5
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Thanks man - appreciate the encouragement. I know you have 19s, what are your wheel/tire/suspension specs again?
Originally Posted by OG_M3 View Post
imho front tires look a little too "fat" - which is probably the source of your problem. a 245/40 or 255/35 will alleviate the problem.
Side wall height, right? I mean, it is the stock rear size, maybe too much up front though. I guess, yeah, too much with my rubbing issue. So if the current plan is the minimal drop from dinan springs, which tire size would be the better fit?
      08-22-2010, 08:25 PM   #6
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
+1. They do look just a tad bit wide...but I bet you get phenomenal mechanical grip.
      08-22-2010, 08:32 PM   #7
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
yeah, it's got great turn and initial grip. Can't say that I've pushed it real hard, tires are pretty new (< 200 miles).
      08-23-2010, 10:28 AM   #8
crfine88
crfine88's Avatar
442
Drives: E86M
wheels look great.
You will need more negative camber and a shorter tire to run that front wheel size, but you can make it fit.
