      03-08-2023, 11:09 AM   #1
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
O-ring installation, lubrication....
BMW colleagues -
Preparing to install the aftermarket aluminum chargepipe which mates to the throttle body and the chargepipe is engineered to receive a specific o-ring.
Began searching this subject re how to install the o-ring to prevent damage, if and what type of o-ring assembly lubricant, etc.
Found this website that is a a quick read and provides excellent direction re preventing o-ring damage during installation, etc.
Please take a look and offer your experience and recommendation(s) re what type of lubricant to use on the o-ring prior to installation.
The website refers to ester based lubricants and petroleum distillate lubricants as well.
If you have a recommendation, please post (and hopefully a weblink) for a small tube of lubricant for my application.
https://www.ipcol.com/blog/everythin...-installation/
Thank you and regards -
Racerbruce
Racerbruce
      03-08-2023, 01:53 PM   #2
cbpip
cbpip's Avatar
151
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Here is a guide to help with different type material o rings and compatible lubricants. I use silicone based lubes where needed. Food grade mineral oil as well.
http://www.fluidseals.com.au/article...ication-guide/
https://www.amazon.com/gp/aw/d/B000C...b_b_asin_title
https://www.amazon.com/4oz-Lube-Tube...8305844&sr=8-8
racerbruce3853.50
      03-08-2023, 04:19 PM   #3
racerbruce
racerbruce's Avatar
3854
Thank you -
Thank you cbpip,
I tried Burger Motorsport and Turner Motorsport and neither could provide me with this o-ring's specific composition of material (as noted in your o-ring app guide).
https://www.turnermotorsport.com/p-4...uine-bmw-part/
DOES ANYONE HAVE ACCESS TO THE TYPE (VITON, NEOPRENE, NITRON ETC) OF OEM O-RING NOTED IN MY WEBLINK NOTED ABOVE? - THANK YOU
I'm trying to ensure the OEM chargepipe o-ring is compatible with the assembly lube I purchase.
Racerbruce
      03-08-2023, 08:36 PM   #4
jwolf
Drives: 135i M-Sport MT N-55 / Z4 3.0i
I use this or the 3M brand of clear silicone paste.
https://www.amazon.com/Tribology-Tec...NsaWNrPXRydWU=
racerbruce3853.50
      03-09-2023, 07:32 AM   #5
racerbruce
racerbruce's Avatar
3854
An interesting read -
https://www.thomasnet.com/articles/h...terial-makeup/
Racerbruce
      03-09-2023, 07:45 PM   #6
Rafichicago
Rafichicago's Avatar
Drives: 2018 M5 2009 E63AMG Wagon
Every time i have rubber o-ring I use silicone spray. It’ll make installation easy it’s safe for rubber and than evaporates. Any petroleum based lubricant will damage o-ring.
racerbruce3853.50
      03-10-2023, 02:01 AM   #7
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
As a general rule of thumb I use whatever fluid is in the actual part (engine oil, gear box oil, rear axle oil), if not I preferably use silicone based products. Can't confirm it but an old trick I heard of many years ago is using ATF (Automatic transmission fluid) as it doesn't denature rubber.
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
racerbruce3853.50
      03-10-2023, 03:38 PM   #8
wdb
dances with roads
wdb's Avatar
4732
The Krytox GPL205 lube I used on my origami top seals is an O-ring lubricant. Check the specs against your needs.
      03-10-2023, 05:12 PM   #9
racerbruce
racerbruce's Avatar
3854
thanks wdb -
as my post states, i cannot id this o-ring's type (viton, nitrile, etc).
many of the posts include links to sites where o-ring assembly lube is paired with specific types of o-rings (viton, nitrile, etc) - hence my pursuit to hopefully id the bmw oem o-ring type in the link i posted.
turner motorsport, burger motorsport, etc cannot provide me with the info i am pursuing.
Racerbruce
