10-26-2020, 11:38 PM | #67 | ||
Rep 14,131
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous 2018 F80 ///M3 CS 2016 F80 ///M3 IG: Raging_G82 |
RMachuca3d724.50 |
10-26-2020, 11:59 PM | #68 | ||
Rep 14,131
The majority of fires in CA are federal land. It's LITERALLY NOT the states job to manage wildfire prevention in those areas. Not only that, what are you comparing CA's performance in wildfire management to? Certainly not a state like FL, which has a totally different climate and landscape. Hmmm.. We have an ideal comparison right here in CA-federally managed National Parks. Two different bodies in the same region dealing with the same problems. Guess what: the federal government isn't doing any better.
RMachuca3d724.50 |
10-26-2020, 11:59 PM | #69 |
Rep 2,132
The real world isnt a 1 or 0. There are consequences to every decision, including the one you think is so logical.
10-27-2020, 12:02 AM | #70 | |
Rep 2,132
I’m comparing a burning state to states which don’t burn. Not your job so let your state burn? OK. The federal government is trash too. We agree on that. |
10-27-2020, 12:10 AM | #71 | ||
Rep 14,131
Not sure if you know this but there are already talks for more coordination between state and federal agencies for wildfire prevention in CA. I'm comparing apples to apples. Hawaii isn't going to burn not because they have good wildfire management. It's a wet climate. Just as CA doesn't have world class Polar Bear management- there's no polar bears here. So again, what are you comparing CA to? The weather is dry and hot with lots of forestry. There are going to be much more fires here than a state like Florida. Comparing "states that burn to states that don't burn" is counterproductive. That makes no sense. You choosing to ignore infection rates doesn't make them invalid. You accuse CA for letting it burn, yet infection rates which have killed more people than wildfires are not important enough to be considered? Seems like cherry picking.
10-27-2020, 12:26 AM | #72 |
Rep 3,338
Drives: X5 & E90 WTCC Racecar (SOLD)
Can anyone help me understand why the only thing talked about/shown on media is the upward rate of growth in COVID cases without a mention of the current mortality rate or hospitalizations? A reasonable person would think that those last two would be critical toward understanding the current state of this pandemic and how we should respond.
See recent piece with data gathered from Covidtracking.com. Note orange vs blue lines. |
10-27-2020, 12:56 AM | #73 | |
Rep 14,131
Edit- it could also be that early cases were more concentrated in the elderly and immunocompromised which makes sense. We are basically the survivors of that early wave, so our fatality rate will be different.
10-27-2020, 06:53 AM | #74 |
Rep 3,040
It's really pretty simple, if you do a short, sharp lockdown you can all but snuff this thing out but no you gotta go half arse it and re-open too early then it drags on for months on end.
Life is pretty much back to normal in Australia with no virus circulating, picking people off. I use AUstralia as the example as NZ has far, far less air traffic so easier to shut it down arly. |
10-27-2020, 09:45 AM | #75 | |
Rep 14,131
10-27-2020, 10:24 AM | #76 | |
Rep 2,132
Your virus status is likely more geographical and a result of a large country with small population than anything youve done particularly well. |
10-27-2020, 10:28 AM | #77 | |
Rep 2,132
Plus, the land you do control continues to burn, which demonstrates you couldnt handle it either way |
Dog Face Pony Soldier9719.50 |
10-27-2020, 12:20 PM | #78 | |
Rep 3,040
Chinese travel to Australia is monumental. Truth is, they moved early, shut the border hard, enforced a policed 14 day quarantine and snuffed it out. These were all options other countries could have taken but either didn't or did not do them for long enough or with enough enforcement (the quarantine of incoming travelers is absolutely vital). We are now in a position to recover the ecomony and go about life relatively normally whist the rest of the world will be stuck dealing with this thing in a half arsed manner. |
jmg18816.50 |
10-27-2020, 12:36 PM | #79 |
Rep 1,965
jmg18816.50 RMachuca3d724.50 |
10-27-2020, 01:35 PM | #80 | ||
Rep 14,131
10-27-2020, 03:57 PM | #81 | ||
Rep 14,131
California does a bad job: "it has nothing to do with geography and everything to do with how you dealt with it"
RMachuca3d724.50 |
10-27-2020, 04:06 PM | #82 | |
めらみぽっぷ fan
376
Rep 345
It's a big state. A lot of good, but its fair share of bad too. The negative remarks are largely fair and valid. You can say similar things about NY, particularly NYC.
2020 330i xDrive in mineral white.
Username and profile picture in admiration of the goddess of treble, めらみぽっぷ (Meramipop). https://www.youtube.com/watch?v=fQYWhQXOeQg https://open.spotify.com/playlist/1w...1L3y6cmPEyGSoI |
sirdaft12204.50 |
10-27-2020, 04:42 PM | #83 | ||
Rep 14,131
My post was aimed at covid and wildfire responses. The arguments are contradictory and cherry picking. But if want to change the subject, that's fine: Economic osmosis. Property/taxes gets too expensive, people/businesses leave. If too many businesses leave, then the state attracts with incentives. It's all a natural cycle of economics and capitalism. CA is still highly desirable because of location and talent pool. People generally want to live here even if its expensive, and these people are desirable by employers, or they start their own businesses. Quote:
That's just geography. Throw in a desirable weather and people wanting to live here but can't really afford it and you net poverty and overpopulation. Then you the perpetual nature of diversity. The more diverse the people, the more comfortable other people of similar ethnicities will be to live there as well. Now you have racial tension. With fair weather you get a population of homeless that can make it through winter without dying and thus attracts more homeless people from around the country. How can anyone fairly compare CA to a state with: wet weather and very little wildfires, cold winters that discourages the homeless, and a diverse dense population?
10-27-2020, 04:51 PM | #84 | |
Rep 1,921
However even if it's not CAs fault. It doesn't make it any better. I mean FL is hot as fuck in the summer... if you have issues with heat I'm not gonna sit here and say welllll you know.... it's Floridas geography.... not its fault.... it's still awesome. No. It's hot as fuck all and if you don't like the heat it sucks ass. If you like the heat and jumping in the pool or going to the beach on a hot day it's awesome. If you like forest fires, high taxes, crazy energy prices with rolling blackouts, water shortages, etc.... CA is awesome sauce! I like San Diego... if they forced me to move to CA that's where I would go... assuming I could even afford a house there... or my electric bill. |
Merami fan376.00 |
10-27-2020, 09:38 PM | #85 | |
Rep 2,132
Personally, I believe almost nothing we do impacts Covid much. It’s out and will do what it does. Anyone doing “better” is likely benefiting from geographical or other advantages (generally luck) we don’t understand and we don’t control. |
10-27-2020, 10:08 PM | #86 | ||
Rep 14,131
But to your point, CA isn't doing much better but like you said, it's more dense, so we should be doing worse. But we're not. And you are wrong. People understand epidemiology. It's understood.
10-27-2020, 11:51 PM | #87 | |
Rep 2,132
As I said, Australia is doing better with Covid bc of geography, but California isn’t doing poorly enough to keep Disney and others closed. Everything isn’t comparable...just bc Australia is doing better today doesn’t mean California should be held to that standard. It may be unattainable and out of control bc of the geography, as one example. On the other hand, the fires are arguably bad enough that California should take better steps for prevention, bad geography or not. It’s the state’s problem and each state has its own challenges. The housing, electricity, and air quality concerns are other examples. It’s all about what makes sense. People of California deserve to work, not have their land burning, decent air quality, affordable housing, and electricity. Covid is far down the list of your problems but you’re treating it like public enemy #1 and it’s killing people. They also aren’t working in a vacuum without consequences. Your actions for Covid have dramatic impacts to the people of your state. Last edited by BayMoWe335; 10-28-2020 at 12:06 AM.. |
10-28-2020, 01:07 AM | #88 | ||
Rep 14,131
Where are you from so I can tell you what your state is doing wrong any why you are so bad at everything? Texas?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous 2018 F80 ///M3 CS 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 10-28-2020 at 01:48 AM.. |
