12-19-2020, 01:38 PM | #1 |
Rep 138
Best place to get Vorshlag Camber Plates for Z4M
I have a 2007 Z4m. Looking to get camber plates for KW3 Coilovers I already have to modify camber and castor on the vehicle.
1) Where is the best place to get them? 2) I want to get those teflon thrust bearings/washers to limit coil bind/noise. 3) What type of plate do I need to ensure the strut tower is protected. I do have oem strut brace going from shock to shock. Thanks in advance.
2007 Z4M Coupe. KW3, Stoptech ST60/ST40, SSK, AKG Bushings, 4:10 Diff, ARP Wing, ARP Splitter, MFR Splitter Underpanel.
12-22-2020, 11:56 AM | #2 | |
Rep 104
2) same source, thrust sheets / torrington bearings do this same job well 3) Get Ground Control instead of Vorshlag, having tried both (properly set up, natch), GC has been quieter. GC street plates are quieter still because they add a poly spring perch isolator instead of letting metal spring sit on metal perch. You'll need to specify that you're running KW V3 when ordering, the spring perch and strut inserts (size and shoulder shape) will vary. There are reinforcement rings available for the strut towers if you are worried about big hits at the track / lots of rough road miles cracking the OEM metal. |
wdb4732.00 |
02-07-2021, 11:38 AM | #3 | |
Rep 11,667
I had issues with a noisy GC camber plate and they were terrible to deal with. I've had Vorschlag on 2 different cars and they were great. They stood up well to track usage as well. |
02-12-2021, 03:49 PM | #4 | |
Rep 104
lafuerza I've moved on to GC + MCS 2wnr setup, but I'll gladly sell you mine. DM me, they'll be cheap. If KWV3 strut shoulder is same size/shape as Bilstein, you won't even need to change the bushing/insert. |
inTgr8r2431.50 |
