09-10-2019, 11:07 AM | #1145 | |
Rep 2,250
But on Width day, I start with pull-ups. My programming might have me doing 8 sets of 3 reps with 50lbs hanging from me one time, and then 6 sets of 5 reps with 25lbs hanging......followed by doing them with just my bodyweight for as many reps as I can get with a 1 minute rest between sets. Those are called EMOM (Every Minute On the Minute) sets. Only when I fail to get 5 reps is that one giant set over and I move on to other exercises. As far as grip style, I use an overhand grip. Also I put my arms out to the side, elbows at a 90° angle so my forearms are straight...and that is the grip width I use. Similar grip to a bench press but I'm pulling instead of pushing. That's where I find I'm strongest at. Also....it's an exercise you don't see a lot of people do, but if you have a pull-over machine..we have a Nautilus one....it's an awesome exercise for building width if you using your elbows to force the bar down and contract the lats...then get that extreme stretch back up at the top!
Everybody has a gameplan....until they get punched in the mouth.
overcoil3073.50 |
09-10-2019, 11:10 AM | #1146 | |
Rep 2,250
Then by the time you are ready to cut again...you will be in a pretty good position!
09-10-2019, 12:19 PM | #1147 | |
18031
Rep 9,378
Rmtt8211.00 |
09-10-2019, 02:58 PM | #1148 | |
Rep 156
Another thing worth looking into is the book, "Total Immersion." I found it really helped my swimming. https://www.amazon.com/Total-Immersi...s%2C355&sr=8-1 FWIW, I've done up to a three hours swim. (Reminds me of Gilligan's Island). Last edited by hogwldfltr; 09-10-2019 at 04:00 PM.. |
09-10-2019, 04:56 PM | #1149 |
Rep 14,521
Back day! so this morning I was at the gym and had a pretty awesome back workout. towards the end of my workout there's this pretty cute chick that I'm friends with was doing flat bench press and she asked me to spot her since she was lifting more than she normally does. she had 35's on each side and she was able to rep out 2 of them. i was impressed and she really wanted to know if she can do 135lb and I told her go for it! now this chick is pretty cute like I mentioned but not only that she loves to wear just a sports bra and her gym shark yoga pants. she's a redhead and stands only 5'1 and probably weighs oh I dunno 110lbs? maybe 115? anyways i'm spotting her and i'm sorta distracted cause i'm staring down her abs to her crotch to where I can clearly see the outline of her thong. It was killing me as I can clearly see her snatch. I mean...it was camel toe action! i'm hoping she didn't see me staring but anyways she was able to get one complete rep and as I help her rerack the barbell she jumps up and hugs me with excitement but i'm hugging her with my ass out just so she doesn't feel my crotch as there would have been a surprise for her. anyways, I thought it was a very interesting workout this morning. thank god it's Whackoff Wednesday tomorrow!
King Rudi13154.00 |
09-10-2019, 05:31 PM | #1150 |
Rep 1,144
^lmao got a kick out of the end of that
lsturbointeg9158.50 |
09-11-2019, 05:42 AM | #1152 | |
Rep 2,250
lsturbointeg9158.50 King Rudi13154.00 |
09-11-2019, 06:02 AM | #1153 |
Rep 2,250
So this morning was shoulders and arms. I have been experimenting with various exercise combinations for biceps...and came up with a sequence I think works pretty good. One of you guys should give it a try and see what you think.
1st exercise - Some type of curl where your elbows are physically behind the plane of your body. Like Incline Bench DB curls, Drag Curls, and one I like is the ISO Cable machine where I can step forward and kind of lean over. The curl starts with my arms pulled back behind my body stretching the biceps, and the finished position still has me with my biceps contracted, but my elbows are behind me. This works the long head of the biceps very effectively. 2nd exercise - Some type of curl where your elbows are in front of you body. Something like preacher curls, spider curls, etc and keep your grip more narrow than normal. This works the short head of the biceps. 3rd exercise - any type of Hammer curl as this works the brachialis muscle. Most people don't know it, but the brachialis muscle has a larger cross-sectional area than the biceps. This muscle will elevate the peak of your biceps, and when your body fat is low enough... you can see it as a golf-ball looking bump between you biceps and triceps on the side of your arm. It makes your arms look thicker when viewed from the front. Hammer curls are great for it, but I have an exercise that I was taught years ago that really isolates them. By bringing your shoulders overhead, you can really isolate this muscle. Imagine standing in front of the Lat Pulldown machine....but instead of the long bar you have a cable curl bar on it. You just simply reach up, grab the bar, and curl it downward trying to reach behind your head for peak contraction. Do this at the end with lighter weight and higher reps to finish off your biceps. The pump is crazy! Sorry for the long post...but this is my PSA for today. If you try this out, be sure to post your thoughts on what you think of it. I have only started doing this for the last 3-4 weeks...and I can see a difference already.
09-11-2019, 07:23 AM | #1154 |
Rep 14,521
It's the only muscle that seems to grow
Rmtt8211.00 |
09-11-2019, 08:28 AM | #1156 |
Rep 1,965
09-11-2019, 08:34 AM | #1158 | |
Rep 1,965
I'd also like to thank Rmtt for some solid advice. By no means am I huge, but definitely seeing results. Getting leaner and seeing more muscle mass in a short period of time. I catch people staring at the veins, popping out of my forearms, like they are boobs or something. |
Rmtt8211.00 |
09-11-2019, 11:32 AM | #1160 | |
Rep 2,250
It's a lot healthier too. Your A1C levels will start trending downward, and anytime you can increase insulin sensitivity...you tend to partition extra calories when bulking into the muscle more readily. And as time goes by you start to build up some insulin resistance and your body will eventually get to where it doesn't care where it deposits excess calories...it's just going to store them. The way I look at it...it's a marathon. Might as well look good while you are doing it!
King Rudi13154.00 |
09-11-2019, 12:08 PM | #1162 |
Rep 1,144
A good caloric deficit and intense workouts should be all you need amigo. Best tip I have is just to stay diligent and try not to cheat. When it comes down to it cutting is just a little test of will power. Don't let the fact that you're cutting become an excuse for performing less in the gym, try to keep your expectations high and bust your ass
Shiza1194.50 |
09-11-2019, 12:41 PM | #1163 |
Rep 14,521
Kinda annoyed this morning during my shoulder workout. I use my phone with the timer to let me know when 60 sec between sets have passed and I dunno but usually I keep to myself but today I was interrupted 3 times by guys just wanting to shoot the shit. I would glance at my timer and see that freakin' 3 minutes have passed and this mofo wants to talk about his work? After 6 minutes I literally had to interrupt him and say sux to be you and I'll talk to you later. Not more than 10 minutes go by and this new gym trainer whose skinnier than shit decides to interrupt me in the middle of my set and says he thinks it would be a great idea if he trains me. I said with a straight face "Seriously?" I told him without sounding like a dick "first of all dude gym etiquette you never interrupt anyone in the middle of their set! Yet alone stand in front of me where you can get injured from me smacking you with these dumbells!" The last one I can't get mad cause she was hot and wearing yoga pants so she gets a pass
Rmtt8211.00 |
09-11-2019, 12:58 PM | #1164 | |
Rep 1,144
Rmtt8211.00 lsturbointeg9158.50 |
09-11-2019, 01:19 PM | #1165 | |
18031
Rep 9,378
09-11-2019, 01:27 PM | #1166 | |
Rep 2,250
But it will contract so hard....it will almost cramp on you!
JP102465.00 |
