      05-18-2017, 02:28 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
► New Stronger & Lighter SM-10 & FL-5 Wheels by APEX
Last year APEX worked with the community to develop a new and improved track wheel. Over 700 of you took our lengthy survey and we ended up moving forward with both proposals instead of just one. You wanted a wheel that was lighter and stronger than our more recent designs. The SM-10 and FL-5 were developed based on your feedback.
Both wheels arrive early-mid June 2017, and we’re already working on expanding the number of available sizes.
Feature Highlights:
  • Lighter by 2 lbs. on average vs. EC-7
  • Stronger than all prior designs
  • I” Beam Machining on spokes
  • Revised inner lip design
  • VIA certified in Japan to JWL standard
  • BBK clearance including 380mm kits
  • OEM mounting hardware and stud kit compatible
  • OEM center cap compatible
  • TPMS compatible
The SM-10 and FL-5 designs are APEX’s first wheels to feature advanced CNC machining that removes material along the sides of every spoke. This creates a stronger and lighter “I” beam spoke design. To get a similar styling cue, many other brands just use aesthetic accent lips on their designs which add material and weight.
Style is the lowest priority on our list. We prioritize function over form. These wheels keep the superior BBK clearance of our older EC-7 design. Brembo 380mm and other 380mm kits can clear. We beefed up the inner lip by adding extra material, resulting in better protection again bends during serious abuse.
These Evolution line designs are produced via flow-forming. This process roll forges the barrels, reducing weight and gives the wheel the strength it needs take on the street and the track.
SM-10 Sizes and Specifications
The SM-10 combines a straight 10-spoke design with “I” beam machining to produce a lightweight wheel that is a departure from our traditional mesh styles. Multiple face profiles continue to provide superior big brake clearance and maximized concavity for all sizes.
  • 18x8.5” ET35 - 18.4 lbs. - Arriving June
  • 18x9.0” ET30 - 19.5 lbs. - Arriving June
  • 18x9.0” ET42 - 19.3 lbs. - TBD
  • 18x9.5” ET22 - 20.5 lbs. - ETA Q3
  • 18x9.5” ET28 - 20.3 lbs. - Aug/Sept. Dependent on M2 Group Buy
  • 18x9.5” ET35 - 20.0 lbs. - Arriving June
  • 18x9.5” ET43 - 19.9 lbs. - TBD
  • 18x10.0” ET25 - 20.5 lbs. - Arriving June
  • 18x10.0” ET33 - 20.7 lbs. - TBD
  • 18x10.5” ET22 - 21.4 lbs. - ETA Q3
  • 18x10.5” ET40 - 21.2 lbs. - Aug/Sept. Dependent on M2 Group Buy
  • 18x11.0” ET44 - 21.0 lbs. - Arriving June
Profile 2 Face
Profile 3 Face
FL-5 Sizes and Specifications
The FL-5 takes advantage of Dual Flow Forming plus our newest “I” beam machining technique. Still a one-piece wheel, the Dual Flow Forming strengthens both inner and outer barrels while maximizing front lip depth for each unique width and offset
  • 18x8.5” ET35 - 19.0 lbs. - Arriving June
  • 18x9.0” ET30 - 20.2 lbs. - Arriving June
  • 18x9.0” ET42 - 20.0 lbs. - TBD
  • 18x9.5” ET22 - 20.2 lbs. - Arriving June
  • 18x9.5” ET28 - 20.9 lbs. - Aug/Sept. Dependent on M2 Group Buy
  • 18x9.5” ET35 - 20.5 lbs. - Arriving June
  • 18x9.5” ET43 - 20.4 lbs. - TBD
  • 18x10.0” ET25 - 21.0 lbs. - Arriving June
  • 18x10.0” ET33 - 21.4 lbs. - TBD
  • 18x10.5” ET22 - 21.3 lbs. - Arriving June
  • 18x11.0” ET44 - 21.6 lbs. - TBD
Medium Lip
Deep Lip
Gallery
Click the images to view more finish options on Flickr
      06-01-2017, 03:29 PM   #2
Expert@ApexWheels
3530
Drives: M3
We love the new design of our SM-10 and FL-5 wheels! Here are some up close beauty shots of the new “I” Beam Machining on the spokes :thumbsup2:
      06-01-2017, 03:52 PM   #3
308tr6
Drives: Z4MC?
Tires
Look awesome!
For a 18x8.5 ET35 front, and 18X9.5 ET35 rears (SM10)
What are the recommended tire sizes, respectively? No rubbing wanted.
      06-01-2017, 06:38 PM   #4
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Wow the sm10s look great, tempting
      06-04-2017, 10:59 PM   #5
scrammer
scrammer's Avatar
Drives: 2017 M3 Ultimate
Both wheels look great!
I wish you could have maximized the concavity of the FL-5 by eliminating the lip on one version (deep lip - medium lip - no lip).
I just love the way the lug holes line up on the split spokes of the 5
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
      06-05-2017, 04:06 PM   #6
Expert@ApexWheels
3530
Drives: M3
Originally Posted by 308tr6 View Post
Look awesome!
Appreciate the kind words! I would suggest going with 235/40-18 and 275/35-18 tires respectively.
Thank you for the feedback! We are always open to idea's and suggestions
-Matt
      06-05-2017, 04:09 PM   #7
Expert@ApexWheels
3530
Drives: M3
Check out these detail shots of our FL-5 wheels which showcase the new "I" beam machined spokes, and the new lip design!
      06-05-2017, 10:18 PM   #8
3002 tii
3002 tii's Avatar
2288
FL5's are the best looking out of the Apex lineup IMO...
Follow for latest mods
kaybat125.50
      06-07-2017, 05:25 PM   #9
Expert@ApexWheels
3530
Drives: M3
We appreciate the feedback! We think they look great
-Matt
      06-07-2017, 05:35 PM   #10
Expert@ApexWheels
3530
Drives: M3
Here is another great shot showing the differences between the FL-5 and SM-10 wheels!
      06-08-2017, 05:09 PM   #11
Expert@ApexWheels
3530
Drives: M3
Here is a first look of the SM-10 and FL-5 wheels in the Satin Black finish!
Sm-10:
FL-5:
      06-09-2017, 05:11 PM   #12
Shutterspeed
Shutterspeed's Avatar
Drives: 2008 Z4 M Coupe
SM-10 hands down best looking wheel. FL-5 is a tad too mustang for my tastes, but still a great alternative. I hope someone powders a set bronze soon!
      06-13-2017, 02:05 PM   #13
Expert@ApexWheels
3530
Drives: M3
We appreciate the kind words! The SM-10 wheels do look great
-Matt
      06-13-2017, 02:06 PM   #14
Expert@ApexWheels
3530
Drives: M3
Here is a comparison of all of the available finishes on the SM-10 and FL-5 wheels:
      06-20-2017, 11:24 AM   #15
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Should have these mounted next week on my blue Z4MC - will be sure to take lots of pictures!
      06-20-2017, 12:20 PM   #16
The HACK
The HACK's Avatar
1821
Originally Posted by Expert@ApexRaceParts View Post
SM-10 18x9.5” ET28 - 20.9 lbs. - Aug/Sept. Dependent on M2 Group Buy
Is this still slated for an August/September delivery? If so it might be a better fit for me than the ET30 9.0" wheels. I'll have to take a few measurement first.
      06-28-2017, 04:34 PM   #17
Expert@ApexWheels
3530
Drives: M3
We appreciate it
The 18x9.5 ET28 is currently available for pre-order directly on our website here! It has an expected January 2018 arrival
-Matt
      06-28-2017, 04:35 PM   #18
Expert@ApexWheels
3530
Drives: M3
Here are some on-car pictures of the FL-5 wheels on a Z4M
      06-28-2017, 07:07 PM   #19
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Is the SM10 18x9.5” ET35 - Face2 0r 3
It would be nice if you added the profile for each wheel on the list
      06-28-2017, 08:29 PM   #20
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
inTgr8r
It's SM-10 18x9.5 ET35 is Type 2 face.
FB Group-- > fb.com/groups/z4group
FB Page-- > fb.com/Skyermotorsport
inTgr8r2431.50
yousefnjr6159.00
      06-29-2017, 07:44 PM   #21
The HACK
The HACK's Avatar
1821
That wheel looks like it just BELONGS on the Z.
      06-30-2017, 11:15 AM   #22
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Lordy, I might have to get a set of these. Spokes look great, wonder if they're a bitch to clean lol
