06-10-2019, 08:44 PM | #1 |
Rep 2,051
Any idea what's leaking under here? Its not from the struts. Driver side. Leaking from right under the corner of the bumper. Going to put a plastic container underneath to collect whatever is leaking to see the colouration.
06-10-2019, 09:05 PM | #5 |
Rep 2,051
No headlight washers but my washer fluid reservoir was bone dry when I pulled it out of storage. Pretty sure I filled it up to a higher level than it is now and the colouration is the same orangey colour of my washer fluid that I used.
06-10-2019, 09:32 PM | #9 |
Rep 2,051
Thanks, good call. Will report back when I figured out precisely where the leak is coming from. At least washer fluid is the least important car fluid especially on a convertible only used on sunny days with no bugs around
06-11-2019, 11:08 AM | #12 |
Rep 4,057
Yeah, I had to hide the tropical-flavored rum coolers from my cat too.
Huz-Z
06-11-2019, 02:04 PM | #13 |
636
Rep 3,124
Remove the bumper cover.
Remove the headlight washers and hoses up to and including the tee. Plug the remaining hose. Take the caps off the washers and attach them to the bumper cover. Problem solved.
06-11-2019, 03:24 PM | #15 |
636
Rep 3,124
There's headlight washer functionality?
At least down here in SoCal, the only function they serve is to break.
WeekendWarriorz670.00 |
06-11-2019, 09:18 PM | #16 |
Rep 2,866
And dirty up the entire car
06-12-2019, 06:45 AM | #17 |
Rep 4,057
That's weird. My E70 X5 has headlight washers that work just fine, even after multiple Canadian winters. My Z4 does not however so I can't comment on them. But maybe the washer design on the Z4 is different and more problem prone somehow.
Huz-Z
06-12-2019, 11:02 AM | #18 |
Rep 754
The headlight washer/windshield washer system in this car is pointless in my opinion. I removed the whole system completely
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold 2006 Z4 M Roadster Black/Black-Sold 2021 M2 Competition DCT Hockenheim Silver |
kaybat125.50 |
06-12-2019, 03:20 PM | #19 |
Rep 1,247
I never understood this. It just sprays fluid on them right? With no wiping or anything? Don' see how that would clean anything except maybe dust. And I think it would make a freaking mess everywhere.
Never thought they would work for crap.
06-12-2019, 03:58 PM | #20 |
10855
Rep 4,893
Thats exactly their function; remove dust/sand/mud (or even snow).
As far as testing their function (in development/typeconformitychecks), there's even an official norm that specifies a certain mixture based on birchsawdust that has to be applied to the lights that the washerjets have to get off for a certain percentage/area etc etc. The jets are required when headlights go over a certain emitted output of light (lumen). Wiping systems on headlights haven't been used since mid 90's or so as they smear the dirt doing more harm than good. A washerjet doesn't have this effect and are therefore safer.
06-13-2019, 05:49 AM | #21 |
Rep 18,733
Kinda like dating a girl, until you find out she has a set of doo-dads between her legs?
06-13-2019, 08:10 AM | #22 | |
Rep 1,247
