      10-20-2018, 10:36 PM   #353
dre99gsx
Drives: 1994 Toyota Supra
295s are possible in the rear. you need the "perfect offset", a tight fender nip and roll. With some rear toe-in, you'll notice the rear portion of the fender where the bumper attaches is the area that needs the most attention. I run R888R 295 (which run wider than most 295), thus I suspect you could fit a 305/30 if you can find one, but do you really need to?
      11-14-2018, 09:53 PM   #354
JimBob0047
Drives: 2006 Z4MR
513m fits the non M Z4 perfectly. Not with OE M3/M4 255/40 and 275/40 tire sizes though. Rear was fine but rubbed two holes in the front fender liners on stock suspension. Had to step it down to 245/35 and 265/35 which is the closest to factory diameter as well. Allowed for some coil overs and lowering. First two pictures are with the OE tires and suspension, last two are with stepped down tire sizes and lowered on BC coil-overs.
3GFX722.50
StigJ331.50
      11-15-2018, 06:49 AM   #355
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Love the plate
I feel like you could space out the rear and dial in some camber.
      11-15-2018, 07:10 AM   #356
JimBob0047
Drives: 2006 Z4MR
Originally Posted by 3GFX View Post
Love the plate
Not without rolling the rear fenders. This setup was right on the line.
      12-31-2018, 03:14 PM   #357
Ealejandrov88
Drives: 2006 BMW Z4 3.0i
Hi folks,
I'm new to this thread I had a couple of questions about wheel fitment and coilovers for a 3.0i roadster I'm thinking of ordering Apex ec-7 wheels staggered 18x8.5-et35 front and going 18x9.5-et43 rear while also running a h&r coilover kit maybe drop the car 1.5" at most. I want form and function while not having to mess with rolling fenders or spacers or any of that what do you guys think any suggestions has anyone had any experience with this type of setup I appreciate the knowledge anyone can offer
      01-02-2019, 11:18 AM   #358
bgeorge0049
Drives: 2006 BMW Z4 3.0si
Originally Posted by Ealejandrov88 View Post
Hi folks,
Have you called or emailed Apex? They are really good at ensuring fitment.
      01-02-2019, 11:27 AM   #359
Ealejandrov88
Hi folks,
I did send them a message they got back to me yesterday and told me to run the 18x9.5-et35 at the back to ensure fitment with the coilovers but I would have to run 255 tire I'd like to run 265 to do that I would have to roll fenders the guy said
      01-02-2019, 03:58 PM   #360
Steeler
Steeler's Avatar
2422
I ran a 265/35 tire on 9.5 and et35. Needed to dial in around 2 degrees of camber. Inside of tires wore out in 2 summers
Dropped down to 255/40 and less camber. No wear on inside shoulders.
      01-02-2019, 04:03 PM   #361
Ealejandrov88
I got ya thanks for the info. I appreciate it
Cheers,
      03-01-2019, 09:28 AM   #362
ZiMMie
Drives: S54/E36
Will anyone(E85/E86 owners) be interested in a complete bolt on kit that will allows the rear axle to achieve the same wheel fitment as the M?
i.e. low offset/wider rear wheels?
      03-16-2019, 09:56 AM   #363
shadowsnkx
Drives: BMW Z4 E85
18x8.5 18x9.5 et35
Is anyone running these wheels? I've looked through the post and its alot to take in.
https://www.ebay.com/itm/New-18-Whee...4/264052445644
Size :
18x8.5 (F) & 18x9.5 (R)
Bolt pattern :
5x120
Offset :
35mm (F) & 35mm (R)
Hub Bore :
72.6mm
Anyone know what style these are?
Recommended tires?
I'm on koni adjustables and h&r springs
      03-16-2019, 11:33 AM   #364
Steeler
Steeler's Avatar
2422
Size :
Bolt pattern :
5x120
Offset :
35mm (F) & 35mm (R)
Hub Bore :
72.6mm
Recommended tires?
https://picclick.com/18-Wheels-Style...582262422.html
Look like style 433 rims.
Those offsets may need a 10mm Rear for flush fit.
I had the same offsets and width on my 04 with Konis and ST coils, using 265/35 and 235/40
      03-24-2019, 11:58 AM   #365
mjsmith9s
Drives: Z4C 3.0si
I have a 3.0si with the m sport suspension. Stock. I have some wheels that are off of a z4m. They are:
Front: 19x8.5 et30
Rear: 19x9.5 et25
From what I gather the et25 for the rear wheels will be the biggest problem?
They ran 235/35/19 tires on front and 275/30/19 on rear for their m. I was thinking a 255 or 265 on rear if it's possible?
Not sure if it's possible to make it work, hopefully you all have an answer. The car is not my daily driver if that helps. Thanks for your input in advance. All these numbers are messing with my brain right now..
Thanks!
      03-24-2019, 01:25 PM   #366
3002 tii
3002 tii's Avatar
2272
Front: 19x8.5 et30
Rear: 19x8.5 et25
Thanks!
(Hopefully others can chime in and confirm but...)
If you go 265 rear you’re want to step up to 265/35 which is pretty much same height as 275/30. So it’s really a width issue, 265 vs 275, both of which are too wide for 8.5 imo. Your wheel setup is basically a square width but different offsets.
Ideally you’d want to run a 255/30-19 square which would is good for 8.5 and maintains rolling diameter of ~25”. Only issue is 255 up front may rub but I actually think it’ll be fine if you pull the camber pins and dial in some negative camber. For the rears, the offsets aren’t ideal as they’re about 20mm lower than factory but it’s not bad. It’ll sit flush with a more aggressive stance. Plenty of folks have thrown 20mm spacers on back.
Alternatively you can step down to a 225/35 in the front without running camber but you won’t get much rim protection on an 8.5 and risk curbing the rims more. Lastly tire choices will impact things too so if you go with an aggressive summer compound you’ll have higher chance of running in rears. All seasons will be less of an issue.
Follow for latest mods
      03-24-2019, 01:53 PM   #367
mjsmith9s
Drives: Z4C 3.0si
Oh sorry. I had a typo. The rear width is 9.5. Probably makes it a bit more of a challenge?
      04-07-2019, 07:00 PM   #368
pegasusactual
Drives: 2003 BMW Z4
Can anyone confirm that style 162 wheels will clear fine on an E85? I mounted the fronts today, and they appeared to protruded far more than the calculated 13mm. I'm concerned about slinging road crap down the side of my newly painted car. The style 202 wheels which came with the car are too bent to be servicable.
      04-07-2019, 08:49 PM   #369
3002 tii
3002 tii's Avatar
2272
I actually think E90 non-m wheels have the best offsets for our cars. If you’re worried about paint then just apply some clear film cutouts on the body panels but any half decent paint job should hold up from the occasional gravel being kicked up.
      04-08-2019, 08:43 PM   #370
pegasusactual
Drives: 2003 BMW Z4
Thanks for the opinion. I must admit it's an upper end Maaco print job, but it's a 16 year old salvage title vehicle.
      05-07-2019, 10:13 AM   #371
3GFX
3GFX's Avatar
Update on more recent findings.
NUMBERS!...for those looking in the future:
Stock Front 18 x 8.0 ET47 // 225/40R18
Stock Rear 18 x 9.5 ET50 // 255/35R18
Rotiforms Front 19 x 8.5 ET35 // 235/35R19
Rotiforms Rear 19 x 10 ET40 // 265/35R19
Hypergram Front 18 x 8.5 ET35 // 235/40R18
--6mm more clearance than stock on inner, same as Rotiform
--18mm extended outer over stock, same as Rotiform
Hypergram Rear 18 x 9.5 ET35 // 265/35R18
--2mm more clearance than stock on inner, 11mm more clearance than Rotiform
--28mm extended outer over stock, 1mm less extended than Rotiform
Ultraform Front 18 x 8.5 ET38 // 235/40R18
--3mm more clearance than stock on inner, 3mm more clearance than Rotiform
--18mm extended outer over stock, 3mm less than Rotiform
Ultraform Rear 18x x 9.5 ET36 // 265/35R18
--1mm more clearance than stock on inner, 27mm more clearance than Rotiform
--27mm extended outer over stock, 2mm less extended than Rotiform
Front Tires:
225/40/18 - stock
--DIA 25.09"
--CIRC 78.81"
235/35/19
--DIA 25.48"
--CIRC 80.04"
235/40/18
--DIA 25.40"
--CIRC 79.80"
Rear Tires:
255/35/18 - stock
--DIA 25.03"
--CIRC 78.63"
265/35/19 (hard to find from some manufacturers)
--DIA 26.30"
--CIRC 82.63"
275/30/19 (running as of May 2019, same rims no issue)
--DIA 25.50"
--CIRC 80.10"
265/35/18
--DIA 25.30"
--CIRC 79.49"
(Hoping to run at some point)
Pirelli PZERO Slicks "DH"
Front
235/645/18
--DIA 25.40"
Rear
265/645/18
--DIA 25.40"
      06-07-2019, 08:56 PM   #372
g2096
Drives: IS300
Aloha could I fit 18x9.5 et30 with a 215 or 225/40 tire up front on a 2008 3.0si z4 same size for the rear but 245/35 tire. Car is currently on BCRacing coilovers.
      06-28-2019, 01:37 AM   #373
Willy Sea
Drives: BMW M Coupe S54, E36 M3 Evo,
Will these fit? 2006 E86 3.0si coupe with msport suspension. Unmodified and stock height.
BBS CH 15 18x8.5 ET 35 Front
BBS CH 18 18x10 ET 40 Rear
Thanks in advance for any comments
Willy Sea
      06-28-2019, 09:36 AM   #374
3GFX
3GFX's Avatar
Willy Sea
Willy, if you would have read only slightly above...
...its the exact setup size wise that I am running except 18".
Search this Thread:
Advanced Search
