02-24-2013, 10:18 AM | #1 |
Rep 155
cigar lighter socket is hot with key off???
I am a new bmw owner. Never owned one before.
My cigar lighter jack is always hot even with key off. Is this normal with bmw??? Also, When I connect charger using cigar lighter socket for my ipod, it make a big "pop" sound through speakers. Same thing happens when I try to connect AUX line to ipod. Is this normal with z4? or is something wrong??? Also when I play ipod through AUX connection, there is constant background noise. Any advice??? |
02-24-2013, 11:51 AM | #2 |
Rep 2,881
Yes...cigarette lighter socket is always hot. Unfortunately, the Z4 doesn't have a socket for a flashlight, which is switched off with the key Otherwise, you can get an adapter for that and use that if you want switched power.
No background noise through the AUX for me. I don't have an iPod, so...can't comment on that. |
02-24-2013, 01:56 PM | #3 |
707
The background noise--is that with the iPod plugged into the charger or just connected to aux only?
My iPhone through aux only (not charging) is fine. Haven't tried while charging. I suppose you could get alternator noise on the line in that way? |
02-24-2013, 02:09 PM | #4 |
Rep 228
Just to make sure you're getting the right advice - you're saying hot as in 12v never shuts off right? If it's temp hot you probably have a grounding problem...
02-24-2013, 02:47 PM | #5 |
Rep 155
I have to check on that. Can't remember right now.
02-24-2013, 02:50 PM | #6 | |
Rep 155
No not high temperature. I was saying hot as in '12v power presented'. Good to know that it's not an electrical problem. BMW is a lot different than other cars. When i opened the hood first time, I was like, "heck, where is battery and oil dip stick??" :-) |
02-25-2013, 10:42 AM | #7 |
Rep 155
I checked it. It hasppens only when the charger is connected. Any ideas???
02-25-2013, 10:51 AM | #8 |
Rep 1,772
Drives: 2007 Z4M Coupe
LOL make sure you never get a Porsche then! I hear those cars don't even have an engine
03-01-2013, 12:30 PM | #9 | |
Rep 238
03-02-2013, 01:18 AM | #10 |
Rep 48
I use my Android through the Aux input and if I connect the charger, I also get the background noise. I believe it is from the magnetic field from the charger built into the phone, as I also get it in my pickup running through an RF Transmitter, only when charging. I ended up purchasing a spare battery and an external charger for the phone.
03-02-2013, 08:08 AM | #11 |
Rep 542
Drives: 2022 X3MC
you want something like this to filter the noise.
http://www.amazon.com/PAC-Ground-Iso.../dp/B001EAQTRI
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI |
03-03-2013, 01:13 AM | #12 |
Rep 51
I have this same problem, even with an inline filter such as the one linked above I still get the same noise its slightly diminished but still there enough that I don't want to listen to anything on that input while charging.
03-03-2013, 05:27 PM | #13 |
///Multiple
2993
Rep 4,243
I discovered the hard way that the lighter socket is hot all the time. I had a Belkin USB converter that I had been using in my wife's 335is in the socket under the glove box. I would use it to power my phone when I was a passenger in her car. I just left it plugged into the socket and I didn't have any problem since that socket has power only when the ignition is on.
When I bought the M Roadster I transferred the charger to my car. I left it plugged into the lighter socket and with the constant power it got warm and essentially melted the glue and it came apart. I'm glad it didn't start a fire!
