      08-18-2021, 06:51 PM   #1
Willy Sea
Drives: BMW M Coupe S54, E36 M3 Evo,
Code out "Start car with clutching"
Our recently imported Z4M coupe from Japan requires the clutch to be depressed
to start the engine.
We wish to code this to off, ie clutch not depressed to start, and tips or pointers please,
Have inpa, ncs and dummy.
All advice gratefully received, thanks for reading
      08-18-2021, 11:00 PM   #2
pungo
pungo's Avatar
Originally Posted by Willy Sea View Post
Our recently imported 4M coupe from Japan requires the clutch to be depressed
not sure what a 4M coupe is, but try this:
Set PARK/NEUTRAL_EINGANG to nicht_aktiv in the EWS module.
      08-19-2021, 03:40 AM   #3
Willy Sea
Its a Z4M coupe sorry pungo for being unclear here. Thank you for the assist.
      09-08-2021, 03:51 PM   #4
Dynamics99
Drives: 2011 E92 & E90 335i 6MT MSport
You could also use PA Soft 1.4 to disable clutch start. Should be the EWS Module. I did that to mine.
