      06-02-2010, 01:16 PM   #1
SSG S
Drives: DINAN Z4
Dinan Throttle Body
Hey all,
I have searched, here and google, but no luck on either one.
I just need instructions on removing and installing this throttle body on my 3.0i :/ If anyone could help me I would be very greatful. Thanks everyone.
      06-02-2010, 03:03 PM   #2
SSG S
Drives: DINAN Z4
Anyone?....
Help is much appreciated.
      06-02-2010, 03:46 PM   #3
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
That is the M54B30 motor right? I used this DIY on my 325i and cleaned it all up. Ran a bit better. Should help you install it. http://forum.e46fanatics.com/showthread.php?t=615503
Careful with the DISA. That orange gasket can get molded to the engine from the heat and when you put it back there can be a vaccum leak. Don't remove it unless you have to.
If you do get a vaccum leak, you can put some wheel bearing grease around the lip of it to seal it up. The grease is thick and will act like a putty that fills in the slight crack between the orange seal built into the DISA and the Intake Manifold. If that doesn't work, you'll probablly have to buy a new DISA.
Also those DISA do wear out and break. When they do, it is possible for the metal pin that is part of the assembly to fall down into the intake manifold which is extremely dangerous if sucked into the engine.
      06-02-2010, 07:47 PM   #4
SSG S
Drives: DINAN Z4
Thanks for the great input Blind
I cant access the link through my phone for some reason but I will indeed check it out when I get home.
The DISA unit is about 4 months new on mine since the old unit was completely shot.
Here is the link.
http://z4-forum.com/forum/viewtopic....231895#p231895
That thing got pretty nasty and I was lucky the pin didnt fall off...
Thanks again Blind32. Ill b back if that link doesnt answer my question
SSG S
      06-06-2010, 01:34 AM   #5
SSG S
Drives: DINAN Z4
Thanks again Blind,
entire procedure took me 1 hour and 28 minutes
Car feels smoother at idle and feels a bit more throttle responsive.
Thanks again.
SSG S
      06-06-2010, 03:07 PM   #6
Blind32
Blind32's Avatar
Drives: '07 Z4MC
Cool, Glad it worked out well. That damn intake boot is a pain to attach to the throttle body. Hard to reach those hose clamps.
      06-07-2010, 11:01 AM   #7
SSG S
Drives: DINAN Z4
Believe it or not it was fairly easy to take them off and put them back on. All the clamps were very cooperative.
Even so I still turned them all facing up when I was finished just in case I have to get back in there later. Car feels great now! I cant wait to autocross it soon
I just wish I had an LSD but thats in the far future now... I think coil overs are my next thing.... But I must say...this is all hurting the wallet quite some. :/
Thanks again Blind
SSG S
