      08-20-2013, 05:18 PM   #1
Kim Schwartz
Drives: 128i
Motor mount heat shield
There is a heat shield on the passenger side motor mount. Does anyone know what is being shielded from the heat and what risk might there if that heat shield was not there? I ask because the people that I hired to install the vibra tech motor mounts did not re-install the heat shield as they did not feel that it was any longer necessary. Any thoughts?
      08-20-2013, 05:51 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
This was touched on in the other motor mount thread.
IMO it should still be used.
There is a lot of heat from the exhaust in that area.
Just because the rubber is encased in an aluminum pot, does not mean that it is protected from the heat
It's probably better than the OE mount, but I figure ever bit helps.
      08-21-2013, 01:54 AM   #3
Beedub
euro cars dont even come with that heat shield...... but the catted headers you guys will create more heat hence the shielding.........
      08-21-2013, 07:38 AM   #4
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
If I paid somebody to install, I would want the heat shield along with it. It can only help prolong the life of the mount. Keep in mind that there is a tab that has to be flattened for it to fit now.
      08-21-2013, 11:17 AM   #5
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
I didn't reinstall mine but I have catless headers that are jet hotted. So, in theory, they shouldn't radiate as much heat as stock catted headers.
      08-21-2013, 12:43 PM   #6
Kim Schwartz
Drives: 128i
Interesting thoughts. You see I'm wondering if I should put them through the bother of reinstalling a part that may not be necessary. I will do it if I really feel that it is a relevant component with the vibra tech mounts.
      08-21-2013, 02:36 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
My left side stock mount was fine when I replaced it.
I thought my right side was fine too, until I removed it and found a big crack that was hidden by the heat shield.
I'm going to wager that it didn't just crack from age alone, it degraded from heat, and it would have degraded faster without the shield.
My recommendation would be to get the shield put back on, or do it your self.
Given what I found, I'm considering adding more shielding.
      08-21-2013, 02:41 PM   #8
Kim Schwartz
Drives: 128i
May I assume that this was with vibra tech mounts?
      08-21-2013, 03:25 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
The crack was in the stock mount.
2006 with 88k miles. Gently driven. YMMV.
Replaced with the vibra tech. As was said, not sure if they have the same sensitivity to heat, but heat + rubber = no.
      08-21-2013, 05:43 PM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
One of the reasons why I'm having my headers coated.
      08-21-2013, 06:32 PM   #11
beta
Drives: 2006 M Roadster
^ another reason to spring for a thick ceramic coating. In the US I recommend swaintech.
      08-22-2013, 09:32 AM   #12
Blind32
Blind32's Avatar
Drives: '07 Z4MC
I had the same experience now that you mention it. The Heat Shielded motor mount was cracked and looked much rougher than the other side. Replaced my motor mounts around 60k and car was ~6 years old.
