07-07-2013, 05:54 PM | #1 |
Rep 832
Scuffing rotors
On a recent wash, it looks like some water sat behind the pads somehow and the next morning, when backing up, the brakes stuck a bit and I have had a minor jutter since then. I have tried bedding them in again (though not aggressively yet) but no change. I have thought about just taking a sanding disc on an angle grinder and lightly scuffing the rotors to remove any deposits.
Any thoughts on this? Has anyone done it? Thx |
07-07-2013, 06:27 PM | #2 |
#dubspec
6336
Rep 5,201
i wouldnt suggest it. maybe some brake cleaner on the rotor and take it for a good thrashing...
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd Last edited by dubsesd; 07-07-2013 at 08:08 PM.. |
07-07-2013, 06:29 PM | #3 |
M = Midlife Crisis
65
Rep 2,006
I always make a few braking runs after washing the car. Even after that from time to time they get rusted on; including yesterday AM - never had a lingering issue however...
2006 Z4MC - #LL93158
07-07-2013, 07:04 PM | #4 |
enthusiast
48
Rep 1,695
07-07-2013, 08:42 PM | #6 |
salty cowboys fan
6158
Rep 3,406
A very light sand might be ok, but I would be scared to do any sort of powered grinding without a dial indicator. If the surface is left uneven it could make it vibrate under braking. I'm not sure of the rotor runout specs for the the car, probably a thousandth or two. There's a chance it might be stamped on the rotor housing. As others have said though, a quick drive around the block after washing is probably easiest.
07-07-2013, 09:20 PM | #7 | |
Rep 832
I often do a run after washing but in this case, I was going to polish and seal the next day so did not want to risk getting any dust/dirt/etc on the paint to save from a rewash the next day. |
07-08-2013, 02:13 PM | #8 |
1821
Rep 5,337
Problem should go away after a few days if car is driven regularly. Rust, unless it's built-up rust on the same spot, will get ground off by the pads eventually. Unless you take the car right now with the high rust spots to the track, i wouldn't even worry about it.
The problem is the hill start holder, if you're parked in an incline, the car automatically puts pressure on the pistons to hold it in place, therefore the pads contact the rotor as you park overnight. End result is, if the rotors are wet, you'll get a rust spot. A couple of tips in this thread is spot on though. After each wash I take the car out for a good 5 minutes with some moderate to heavy braking just to dry the rotors up. And I NEVER park the car with parking brakes after a wash after the FIRST time I did that on my 323Ci. Took quite a bit of effort with that 173HP engine to break free of the rusted on shoe to the drum.
07-23-2013, 08:33 PM | #9 |
Rep 283
About 2 weeks ago I washed my car but had to pull in the garage immediately because it had started raining. 3 days later I took it out for a spin and noticed it felt a lot like when like when my calipers were seizing (replaced 2 in the last year). Does anyone know a way to tell the difference between the two? I jacked it up and the wheel spins freely but you can hear a slight "rub". I was worried I might end up warping my rotors if it was the caliper.
