06-05-2013, 04:53 PM | #200 | |
M = Midlife Crisis
66
Rep 2,006
2006 Z4MC - #LL93158
06-05-2013, 05:08 PM | #201 |
Rep 11,669
06-05-2013, 06:21 PM | #202 |
M = Midlife Crisis
66
Rep 2,006
Still waiting for RE to ship the RTAB's. Ordered at the same time? No correspondence from RE?
09-22-2013, 09:15 PM | #203 |
#buildnotbought
11033
Rep 4,920
I've found a third supplier of offset bushings beside the previously found superflex and bavarian auto/whiteline offset bushings.
http://www.nolathane.com.au/ They're maybe affiliated with whiteline? (both australian and some drawings are in the same style) Edit: they're based at the same address..... Strangely they (nolathane) have 2 variants of the 66mm offset bushings: http://www.nolathane.com.au/product_...t_number=45553 http://www.nolathane.com.au/product_...t_number=45555 the 45555 have "LH offset - RH standard alignment" whatever that means.... (a lefthand offset bushing and righthand non offset?!? does that work?!? )
09-24-2014, 08:55 PM | #204 |
Rep 170
Hey shipkiller,
How did these work out? I bought a set of these, but never installed them. Any issues? Thanks.. Quote:
09-25-2014, 04:55 AM | #205 |
Rep 2,138
Drives: Me
01-11-2016, 02:28 AM | #206 | |
Rep 1,923
01-11-2016, 07:38 AM | #207 |
Rep 11,669
They are holding up great.
Yup, plug & play
07-15-2016, 01:16 PM | #208 |
Rep 195
Am I to understand that the Superflex bushings are easier to install given the multi-piece design? If I have to make special tools to bolt in the lollipop, I may not be interested in this as a DIY job.
Thanks in advance! |
07-15-2016, 01:31 PM | #209 | |
Rep 11,669
If you want easy, just get OE with bush and lollipop complete Anything else you will also have to press out the old bush from the lollipop before pressing in a new one.
07-16-2016, 04:23 PM | #210 | |
Rep 195
I was referring to Shipkiller's post above. He seemed to be implying that the 2-piece units might be easier to reinstall. I figured I would get a machine shop to press out the old bushings and press in the new ones. I just didn't want to get everything back together and find out that I couldn't bolt the lollipop back onto the car without fabricating tools. I have 50K miles on the M Coupe, and I'm trying to figure out how far I want to go with a suspension refresh. My FCABs actually look fine, but while I'm in there doing struts... |
07-16-2016, 08:58 PM | #211 |
Rep 2,138
Drives: Me
If you are using stock FCABs, the you should have no issues getting them back on.
If you look closely at the pictures, I am not using anything near stock, so they are really, really stiff, and I had a hell of a time getting the bolt holes to line up. The 'Whiteline's' I used are stiffer than the Superflex or Powerflex FCABs. |
