03-08-2012, 09:43 AM | #23 |
Rep 72
Wheel Wizard said the wheel is repairable. They said it will not look pretty.
I'm attempting to locate a used wheel. http://www.zpost.com/forums/showthread.php?t=659112 |
03-08-2012, 12:13 PM | #24 | |
Rep 4,058
There must be some way to repair that rim without spoiling its looks altogether. I think others have had rims refurbished with nice results.
Huz-Z
03-08-2012, 12:53 PM | #25 |
Rep 1,991
That makes no sense as the crack is on the inside of the rim. You would never see the repair. I agree though- it may be easier and cheaper to just buy a new/used wheel and be done with it.
03-08-2012, 01:21 PM | #26 |
Rep 4,058
I broke one of my Style 108s in much the same spot, on the inside edge of the rim, two years ago. I bought a new one, but a local shop assures me that they can fix the broken rim for about $100 or so. I'd expect a used rim would be around $300, and you don't know how badly it may have been damaged, or how well it may have been repaired.
Huz-Z
03-08-2012, 02:30 PM | #27 |
Rep 72
I'm just seeing what is available out there used. I agree no one will see a patch job on the inside of the wheel.
March 8th progress: 1. Shampooed carpet 2. Cleaned interior hard surfaces 3. Applied Leaterique to leather surfaces - I now understand the rub in by hand instructions. It makes the leather more pliable. It's like giving someone a back rub. 4. Cleaned Air Filter 5. Clayed car; really didn't need it. I'm sure the small independent dealer I purchased from had buffed the car out. I did it for the experience (I've never clayed) and to see what Zaino can do. Last edited by All American 6; 03-08-2012 at 06:29 PM.. |
03-08-2012, 03:01 PM | #28 |
Rep 217
Dawn will remove any oils and greases as well as help to strip off any old wax or polish build up. You are absolutely correct about using car wash soap all other times, but when you are underkaing a detail job like this one the dawn actually helps strip everything. The OP wil not want to be anywhere near Dawn after he waxes this baby.
03-08-2012, 03:50 PM | #29 |
Rep 4,058
we now interrupt this thread for a brief musical interlude.
Sorry, sometimes I just can't resist being silly!
Huz-Z
03-08-2012, 07:27 PM | #30 |
Rep 72
4 Seasons! I can't tell if Frankie is there? Sounds like he is.
Claying is done. Prior to claying I could feel some foreign objects (not much). It's baby smooth now. Made the glass look good too. The distinction of image in the paint is pretty good right now before polishing and waxing. You can see the popcorn ceiling by the light bulb. Those two-hundred watt bulbs are my sun light. |
03-08-2012, 09:13 PM | #31 |
Rep 779
Holy cow, how do you remove the seats, I wanna do that !!! i love leatherique
-edit- never mind, i found it.. ill be doing mine soon too
-Roranji
03-09-2012, 06:45 AM | #32 |
Rep 1,991
It is interesting to me your car has extended leather(a rare and expensive option) but no premium package(as the seats are manual). I would think someone who wanted leather everywhere would have wanted power options as well.
Nice work! |
03-09-2012, 08:02 AM | #33 | |
Rep 72
I guess they were at the end of what they wanted to spend. Premium Pkg -Inc: Auto-Dimming Rearview Mirror, Auto-Dimming Exterior Mirrors, 8-Way Pwr Front Seats W/3-Position Driver Seat Memory, Seatback Storage Nets, Passenger-Side Tunnel Net, Bi-Xenon Headlights W/Auto-Leveling, Bmw Assist W/4-Year Subscription, Bluetooth W/High-Capacity Phonebook Download $2,140.00 $2,350.00 |
03-09-2012, 11:58 AM | #37 |
Rep 779
can't wait, right now i'm doing brake swap on my acura.. as soon as that is out of the garage, im gonna pull my seats out and clean it with leatherique and wash the carpets...
-Roranji
03-09-2012, 01:45 PM | #38 | |
Rep 1,991
03-09-2012, 03:31 PM | #39 |
Rep 72
March 9th Update:
Clean the all the leather with Prestine Clean. Great product. Some jack a$$ sprayed the driver's seat with some type of paint. The Prestine Clean removed it (with lots of elbow grease and bristled brush). It took me a few hours to remove it all. I'm kind of mad at myself for not noticing it sooner. Once the paint was removed, I re-applied the Rejuvinator Oil (2 ozs per seat). I'm not sure if I'll leave it, dye it, or reupholster? |
03-09-2012, 04:36 PM | #40 | |
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
"Once you have completed your test fit, we suggest removing the wheel and applying a thin coating of anti-seize around the axle hubs to help prevent rust and permit easier removal when it's time to rotate your tires. Do not apply anti-seize compound to the lug hardware or studs." -Tirerack.com
03-09-2012, 07:14 PM | #41 |
Rep 72
Looks like Leatherique Dye will be the answer to my seat problem.
Anyone here done a re-dye with Leatherique products? Their web site has lots of info on the process. |
03-09-2012, 08:19 PM | #42 | |
Rep 208
Obviously the red threadlocker is used to bond the screw in wheel stud to the wheel hubs - just a drop is needed on the shorter "hub side" of your wheel studs. Once cured it will keep the stud from backing out when you are removing lug nuts at the track. Sometimes heat is needed to help break the bond when removing a wheel stud from an old wheel hub (a torch is helpful). The anti-seize is used on the "lug nut side" of your wheel studs. Again, a drop every few months applied to the outer section of threads will keep the lugs going on and off the wheel studs nicely as well as providing the proper torque specifications without any added "sticktion". |
03-11-2012, 12:20 PM | #43 | |
Car Geek
3706
Rep 3,620
03-11-2012, 04:21 PM | #44 | |
Rep 208
An anti-seize lubricant used on a bolt helps to develop greater clamp load for the same torque compared to an unlubricated bolt. An additional benefit is greater uniformity in clamp load among a series of bolts. Thanks again for pointing out there are differences. |
