Go Back   ZPOST > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Video + PC Gaming / Computing
      07-02-2012, 01:42 PM   #1
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 320D SE  [10.00]
2005 645  [9.00]
Max Payne 3 on 3 monitors!
Great fun on 3 monitors. Loving it.
      07-03-2012, 12:16 AM   #2
RyanM42
x2 is
Drives: 93 E36 318is, 11 E93 335is
Thanks for making the forum 3x my monitor. :P
What's your specs on your rig?
1993 318is [E36] - Silver Gray Metallic - Daily Driver. High MPG ftw.
2011 335is [E93] - Alpine White - Weekend Warrior. fast.
      07-03-2012, 01:28 PM   #3
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
Nothing flash -
i7 860
8gb RAM
GTX 460 and an 8800GT
      07-04-2012, 12:14 PM   #4
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
By at 2012-07-04
By at 2012-07-04
By at 2012-07-04
By at 2012-07-04
More!
      07-05-2012, 09:22 PM   #5
yakev724
yakev724's Avatar
231
Drives: 15 S3
You can pick up an EVGA 570 for under $200 used, and with the new cards, 3 year warranty transfers. Definitely worth the upgrade if you're on 3 monitors.
I'll be doing it myself towards the end of the summer, unless the new 660 has great clocking potential (should be priced around $300 retail at launch).
      07-06-2012, 01:18 AM   #6
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
yeah - looking at upgrading the graphics soon I think. Also ordered this mobo so will need new processor as well.
      07-06-2012, 12:42 PM   #7
yakev724
yakev724's Avatar
231
Drives: 15 S3
Go for a 2500K or 2550K paired with a Cooler Master Hyper 212+. Just did a build myself and went this route.
Either of those chips can run at 4GHz on stock volts (what I'm running) or 4.5 on slightly higher but still safe voltage (~1.35), both air cooled (that cooler is by far the best bang for your buck) and at reasonable temps. There are people running them at 5GHz on water cooling 24/7. Great great chips. Intel also has a $20 additional warranty where they replace the chip if you happen to fry it.
I picked up a 2550k for $170 shipped about 2 weeks ago on hardforum. Also got my mobo there for $100, looking to upgrade graphics to a 570 gtx as soon as the next GPU is released so prices come down a bit.
Tbh, you're better off going for a 670/680 due to the 3-monitor setup, but again, I'd wait a bit for a new release + lower prices.
      07-06-2012, 12:56 PM   #8
- Paul -
- Paul -'s Avatar
England
695
Drives: see above.
2005 645  [9.00]
Do you not think it's worth investing in a 3770K then? around an extra £90 in UK
My 460 is running at 800/2000 so is pretty fast - I may just get another, 2nd hand to sli. Or another 3 to 4 way ! (If I could afford that!)
      07-06-2012, 07:03 PM   #9
yakev724
yakev724's Avatar
231
Drives: 15 S3
Not at all. Invest that money towards a better GPU. At stock speeds (3.4 GHz), a 2500K won't bottleneck a 690 in most circumstances.
As for SLI, it's not worth it unless you already have a top-end GPU and are looking to spend more money. In 99% of other cases, SLI underperforms a single-card upgrade pound for pound.
I'd personally go with an SC 570 or 670/680 if you can afford it. I prefer EVGA since they're popular (easy to find used deals), transfer 3 year warranty, and are very easy to OC. Might want to wait for a bit for the 6** cards to drop in price with a new release, they're significantly more powerful than the 570.
