10-10-2012, 03:12 PM | #199 | |
Rep 11,667
The added straight line on the skirt in that area makes it a jumbled mess of curves & lines. (JMO)
10-10-2012, 03:53 PM | #200 |
Rep 1,443
Yeah, seats look great! (@dsc_off..forgot to quote. D'oh!) BTW my aeros should be done being painted like any second now. I'm so excited to get them on the car (painted reflectors & APR splitter too while I'm at it).
10-10-2012, 04:52 PM | #201 | |
Rep 446
Drives: 2013 335is
2013 335is E93 2018 X5 35d BMWCCA / ZSCCA Member |
10-11-2012, 07:10 PM | #202 |
Rep 1,443
Got my skirts back from the paint shop and put them on this afternoon. I took pics but the lighting sucks so I'm not gonna bother posting them. Does the front portion of the weatherstrip touch the rocker on everyone else's? Mine taper away from the rocker for the last few inches and end up maybe half an inch to 3/4 of an inch from the rocker. I don't recall what the non-aeros looked like before I took them off. I also wasn't able to get the final fastener right in front of the rear wheel well to line up. I might have to jack the car up at some point and redrill to make it work, though it doesn't seem to really be an issue. Everything's tight. Also had a hard time with the mud flaps. A couple of the holes don't line up so I'm gonna have to work on those, too, when I have a chance. Minor issues aside, the match is perfect and they look great. I also got my reflectors/lights painted. The fronts are done but I ran out of time to do the rears.
10-11-2012, 08:26 PM | #203 | |
Rep 11,667
http://www.zpost.com/forums/showthread.php?t=62086
10-12-2012, 08:18 AM | #205 | |
Rep 12,565
10-12-2012, 12:09 PM | #206 |
Rep 1,443
10-12-2012, 02:21 PM | #207 |
Rep 12,565
The easiest but most involved way is to remove the bumper. If you're comfortable removing the bumper, do it. If not, the more annoying and painful (but less involved) way is to access through the liner.
10-12-2012, 09:08 PM | #209 |
Rep 2,866
Before you remove the bumper, try removing the rear light assembly first (much easier - just 3 nuts). If I recalled correctly, after the rear light assembly slides out, you'll have access to that rear corner light.
10-13-2012, 08:53 PM | #211 |
Rep 141
[QUOTE=dubsesd;12794668]they have a very dramatic difference on silver. made a HUGE differance when i installed mine
WOW! That's probably the best picture I've seen of a Z ever! You sure never disappoint with your pictures.
2007 BMW Z4 3.0i. Supersprint powerloop exhaust and center pipe, Aero bumper (w/ clear bra) and side skirts, Avant Garde 19 inch M310's, Koni shocks, Eibach springs, Tekarbon carbon fiber side mirrors.
10-18-2012, 11:17 AM | #212 |
Rep 1,443
Finally got a halfway decent pic. Tough to capture the side skirts on a dark car unless the lighting is just right. I had some trouble refitting the mud flaps but I'll get those on in the near future just because I'd like to have the paint protection. Anyway, since I haven't seen a pic of the on an IB car before, here you go!
10-18-2012, 01:18 PM | #214 |
Rep 1,443
Some of the holes don't match up because the front edge of the aero is wider inside the wheel well than the non-aero. I fitted the drivers side but it looked like crap (my fiancé said it looked fine ) so I removed it and I'll get to it in a couple weeks when I get back from work.
10-18-2012, 03:29 PM | #215 |
Rep 446
Drives: 2013 335is
Looks nice.
11-08-2012, 10:38 AM | #216 |
Rep 1,443
I got the front mud flaps on last night. I had to redrill two holes on each to make them fit and line up properly. The thinnest replacement two-sided tape I could find is a bit thicker than what came with it but only slightly. It was dark when I left my garage last night. When I go back today to put everything back together (I had a few other projects going at the same time) I'll snap some picks for you. It's not pretty in the wheel well but if everything stayed put (mainly tape), which I believe it will, it looks fine on the outside.
12-14-2012, 01:16 PM | #218 |
Rep 862
Ok, has anyone had problems with slight sagging in the front near the wheel well? Like maybe the first 1 inch?
One of mine is absolutely perfect, the other has a ever so slight sag. The one that fits perfectly had to be cut, but the one that is sagging didn't need to be, probably a slightly different mounting design. Thoughts? |
12-14-2012, 02:33 PM | #219 | |
Rep 11,667
I don't recall if you have an M or not & your profile doesn't say (Drives 1???) did you do the trim at that end? (if you have an M)
