      04-06-2022, 09:17 AM   #1
kyriian
kyriian's Avatar
885
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
VANOS Procedure question
Hello
During my removal of VANOs, following BESIAN systems procedure to the teeth. I noted an issue
I had TDC lined up at the crank
The timing holes on the cam are pointed up (I did note my exhaust cam is quite a bit off) so I rotated the cam to point up
Took the VANOS off, and noted the spline gear on the exhaust side is fully inside the exhaust hub,instead of all the way out per the BESIAN procedure
Does it matter where it is on removal? as I have to replace the exhaust hub and chain guide anyways which means I have to remove the exhaust spline.
Revolution of our Times
I will return to the track, one day.
      04-09-2022, 01:50 AM   #2
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
When I was doing it 3 years back the spline gear on the exhaust side was half way in. Didn't have any issue after reassembling.
PS: was going to suggest to call Raj but just realized that he passed away lately RIP...
      04-09-2022, 06:59 AM   #3
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
Originally Posted by kyriian View Post
Hello
You might want to post your question on https://nam3forum.com/forums/forum/m.../e46-2001-2006
There are a lot more S54 owners on that forum than here.
Really sorry to hear that, Raj was a great guy.
Do you know who is running his business now?
2008 E86 M coupe
      04-09-2022, 07:31 AM   #4
grannyknot
grannyknot's Avatar
952
Here it is, I was looking for this thread it just took me a while.
It's just as through as the Beisan procedure but from a different POV.
https://nam3forum.com/forums/forum/m...os-info-thread
2008 E86 M coupe
      04-09-2022, 11:11 PM   #5
vt100
vt100's Avatar
126
Somewhere in this thread they say that Raj' sister runs the business now. And looks like they had been running it together all the time before his death.
      04-11-2022, 07:39 AM   #6
kyriian
kyriian's Avatar
885
2014 BMW X5  [0.00]
They have been super helpful with the work so far, and felt like they are supporting the product they sell.
I got the unit back together now, and had the VANOS pushed up into the motor now, going to proceed with tightening the hub bolts and hope I got it all perfect.
Anxiety is going to make me take it apart just to check the spline gears again, after checking it 3 times already...
      04-11-2022, 04:19 PM   #7
vt100
vt100's Avatar
126
Hehe... I had rotated the crank maybe 10 or 15 times before firing it up for the first time
Best of luck!
      04-20-2022, 01:53 AM   #8
richieadam
Drives: BMW M3 GTR
The timing holes on the cam are pointed up (I did note my exhaust cam is quite a bit off so I rotated the cam to point up
      05-12-2022, 06:51 PM   #9
MadGus
Drives: 2006 Z4MR
2006 BMW Z4MR  [0.00]
If you have INPA, maybe just check the VANOS adaptation degrees before you pull everything back apart again.
      05-17-2022, 10:57 PM   #10
kyriian
kyriian's Avatar
885
2014 BMW X5  [0.00]
Updating the thread, as my procedure went awry.
How does people re-install the VANOs unit back in the car with the spline gears installed? It’s per besians instructions, and countless YouTube sources, I cannot find an alternative method that may work for the limited space in the Z4M
Problem is, the VANOS with spline gears installed won’t fit
      05-18-2022, 02:09 AM   #11
MadGus
Drives: 2006 Z4MR
https://www.zpost.com/forums/showthread.php?t=1112938
Check out post #10. It helped me a lot when I was doing this. Also, I would highly suggest using INPA to check your vanos adaptation degrees after you button everything back up and drive it for a bit.
kyriian884.50
      05-18-2022, 12:52 PM   #12
maupineda
Drives: E86 Z4MC
You need to remove the beauty radiator cover, remove the fan assembly and make the hood release aside (take out the retainer clip)
These gives access from the back of the bulkhead infront of the engine and the whole unit comes out just. Make sure you protect with towels to avoid anything dropping down the engine
Removal of the fan takes 5-10 mins
      05-18-2022, 01:53 PM   #13
kyriian
kyriian's Avatar
885
2014 BMW X5  [0.00]
Yep, I got that part, i needed to remove the fan to get better access to the crank anyway so that's out already
Its re-assembly that was a problem. The post above does outline the variation required for the Z4M so here's to crossing fingers.
      05-24-2022, 01:36 PM   #14
MadGus
Drives: 2006 Z4MR
Keep us posted on how it goes!
      05-24-2022, 02:28 PM   #15
kyriian
kyriian's Avatar
885
2014 BMW X5  [0.00]
Sounds like it is alright, took it to work today with no further hiccups, yay
https://drive.google.com/file/d/1UtX...ew?usp=sharing
      05-24-2022, 02:35 PM   #16
MadGus
Drives: 2006 Z4MR
Great to hear!
      07-11-2022, 09:20 PM   #17
kyriian
kyriian's Avatar
885
2014 BMW X5  [0.00]
I am sadly back again, I have booked time at a shop, preparing myself for the ‘ticket-to-rape-your-wallet-dry-while-post-up-your-mug-for-the-dumbass-who-thought-they-can-but-shouldnt-work-on-anything-wall’ bill
Feels so defeated, three times later it’s still wrong
Took it apart the third time, really paid attention to the position of the spline gear, ensuring it is one tooth next to the position with the least possible rotation, paying attention to have the spline gear sitting just at the entry point of the exhaust hub when I tighten the vanos back on per Besian
Then really taking the time to time the motor, I have the OEM tool,
The first start was tougher than usual
Car was having hiccups, but eventually ran smooth once it is warm
P0017 came back, now accompanied by P1424, how did my MAF get affected I’ll never understand
And also 2F80, 2D06, besides 2AA5 from before also returned
This odd combo of codes is just overwhelming now.
      07-12-2022, 06:33 AM   #18
MadGus
Drives: 2006 Z4MR
Sorry to hear you are having such trouble! If you decide to take another crack at it, maybe give this thread a quick read:
https://www.zpost.com/forums/showthread.php?t=1461862
Camshaft position sensor codes can get thrown when the vanos adaptation is out of spec. Wonder what INPA would show yours to be?
No idea why you are getting the MAF code.
      07-12-2022, 06:34 AM   #19
maupineda
Drives: E86 Z4MC
contact AK72
they are in the GTA, I helped him and perhaps a remote conference would save you some cash. we can go over your car testing with ISTA+, if timing is ok, then your fault can be a failed coilpack.
AK72286.00
      07-12-2022, 10:14 AM   #20
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Last time I did the vanos on a mates M3, it was doing the exact same thing. I took it apart 4 or 5 times before I finally caught into what was going on.. (could probably do it in my sleep now) my mates m3 had a head gasket let go, so there was water in the oil.. I thought I had gotten it all, turns out there was some left... Finally vacated all the water contaminated oil and then it worked like a charm, maybe some food for thought if you've done a head gasket.
      07-27-2022, 05:50 PM   #21
ctdriver86
Drives: e46 m3
I just did my vanos and had no issue. Did you figure this out?
Fatboys Garage youtube has a good video on getting the sweet spot on the splined vanos gears. Followed it and car fired up without any engine codes.
      07-28-2022, 07:31 AM   #22
kyriian
kyriian's Avatar
885
2014 BMW X5  [0.00]
No, haven't had any time, kid's birthday, trying to start a small business, all of it is robbing me of any time i do have.
Talked to Rocco and he gave me some pointers, going to take it apart and see if he is right.
