10-03-2010, 08:37 AM | #1 |
Rep 1,002
M Coupe just died
On my way to Bavarian Autosport Show and Shine. I was driving at about 55mph and the car just died! WTF?
pulled the code reader PEAKE and these are the codes: 2A17: DMTL Diag. Module tank leakage, system failure 2FDA: crankcase vent , system check Stuck on the side of the road waiting for Roadside HELP |
10-03-2010, 09:10 AM | #2 |
Rep 2,782
I googled it and got some very generic answers. This seems to be the best one regarding the 2A17 code:
http://www.bimmerfest.com/forums/arc.../t-461307.html "What exactly does DMTL pump do? The DMTL (Diagnostic Module Tank Leakage) pump tests the fuel tank and fueling components for leaks by slightly pressurizing the fuel tank and evaporative components. The DMTL pump contains an integral DC motor which is activated directly by the ECM which then monitors the pump motor operating current as the measurement for detecting leaks. Basically, it's an emissions device. As they crack down on hydrocarbons from fuel vapors, gas stations have added various forms of vapor reclamation systems on their fuel pumps and auto makers are adding fuel systems that self-test to detect leaks." For 2FDA: http://www.bimmerfest.com/forums/sho...d.php?t=371829 "...the cause can be a damaged or disconnected air supply line. (This cable is located directly on the engine block and it connects the intake bridge with the engine section on the opposite side). This air supply line is to be checked for leak-tightness if any fault occurs!" I say do a general check of the hoses under the hood and make sure your gas cap is on tight. I'm not sure what else you can do right now. |
10-03-2010, 10:23 AM | #4 |
Rep 1,002
Thanks for responds guys! We checked a few things but nothing obvious. Had it towed to the dealer in NH. Will have to drive 160 miles back tomorrow to take care of it. Oh well, it is still under warranty so hopefully they will take care of it.
Mean time, trying to enjoy some great cars at Bavarian Autosport Show and Shine! Will post with what happen tomorrow |
10-03-2010, 05:43 PM | #5 | |
Rep 1,002
I guess i just have to wait until tomorrow and talk to the dealer. |
10-03-2010, 09:41 PM | #6 |
Rep 1,855
Man, I hate to hear stories like this. I hope everything turns out ok.
10-04-2010, 10:34 AM | #7 |
Rep 4,365
Yikes, hopefully it is an easy fix and nothing is wrong. Sucks you had to miss the meet as well!
10-04-2010, 01:58 PM | #8 |
Rep 1,002
Still waiting for the dealer to get back to me. The dealer is in New Hampshire (200 miles from Connecticut) so i can't even go there (just playing phone tag with them).
Hopefully just something simple and no major damage! I will file a complaint with BMW of NA and NHTSA once i find out what happened. It was pretty scaried to loss all powers and abilities to control to the car (even at 50 mph). It could have been worst! I wondered why the car did not go into some kind of "Limp Mode" so I could at least coasting and pull over. By the way, we were able to attend the show and had a pretty good time at Bavarian Autosport |
10-04-2010, 04:10 PM | #9 | |
Rep 615
10-04-2010, 05:32 PM | #11 | |
Rep 1,002
By the way, BMW Roadside refused to have the car tow back to CT. I was left with no choice but to leave my car at some unknown dealer, 200 miles from home. Still waiting to hear back from the dealer about the car. How do you like that and what would you do? |
10-04-2010, 08:04 PM | #13 | |
Rep 615
To O-Cha's point, since the problem appears to be electrical, did you try to disconnect the battery and reattach to see if it reset anything?
10-04-2010, 08:53 PM | #14 |
Rep 1,721
Sounds to me like the engine lost the ability to combust. Either it wasn't getting any air or any fuel.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
10-04-2010, 09:22 PM | #15 |
Rep 1,002
Yes, i did try to start the car several times but it did not turn over. We were on a very busy two lanes road (with know breakdown lane). Since our cars still have hydraulic steering, it was like trying to turn an old school tractor (standing still). I had to pump the brakes several times to get the car to stop.
Since,we were going to a BMW (and Mini) Event, there were quite a few people with lots of knowledges but no one could figured out why the car behaved in such a way. Anyway, those we the codes we got with the PEAKE Scanner. We also, checked all fuses, hoses/cables connections. We stopped short of resetting the ECU because we want the dealer to see the codes. Anyway, all i am saying is that i am not sure what happened! It could be something just got disconnected or bad sensors. It seem to be emission related, and if that was the case then the car should be on "Limp mode" so the driver could slow down and safely pull over. Anyone wants to know what it feels like, drive your car on a very busy road then ask your passenser to turn off the car without telling you (just kidding) All seriousness, i hope it nothing major! And the reason i want to report it so maybe they could look into it (i dont think the dealer would care how it happened) Thank you for the inputs. |
10-04-2010, 11:03 PM | #16 |
Rep 165
Phoenix - keep us updated as to your progress on this. I need to move my service to one of the NH dealerships. Did your coupe go to Nashua or Stratham? I need to decide which of those will take over servicing my ///M roadie. I've visited both and not been real impressed with either - you having your car there for an entire day with no call would certainly bother me in the same situation.
10-05-2010, 05:25 PM | #17 |
Rep 1,002
Wow, my car has been at the dealership for 2 full days now and they have not even do the diagnostic on it yet. Spoke to them 3 times today and they promised that they will get it done today! I am a very patient kind of guy but this is just fucking ridiculous
10-05-2010, 10:58 PM | #18 |
Rep 165
Nashua or Stratham?
10-07-2010, 01:41 PM | #19 | |
Rep 1,002
I am glad everything turn out ok but still a mystery what cause it. I filled up the tank and only was only driven for about 280 miles (i normally get at least 320 miles with city and hwy combined). Not sure if the gas station shut off too early? Or the gauge was inaccurate. I felt like an idiot but definitely learned to fill up as soon as the warning light comes ON. By the way, the light was ON for less than 25 miles when the car shutdown (maybe the twisties cause the pump to lose prime? Oh well, i am glad everything turned out OK. |
10-07-2010, 02:03 PM | #21 | |
Rep 1,002
I finally read the Owner Manual and it stated that refill once the range is within 30 miles. Will never take that chance again!!! |
10-07-2010, 02:04 PM | #22 |
Rep 102
Pheonix, I really do feel badly about your experience and inconvenience, but I find myself smiling at the thought that all this occurred because you ran out of gas.
Again, sorry for you, but it is funny. Do not report this to NHTSA! And, yeah, how do you get 320 miles out of a tankful????? EB |
