11-19-2022, 10:27 PM | #1 |
Rep 45
Blisten B16 install
Hello,
I’m planning on ordering the PSS10 for my Z4MC. Are there other parts I should replace/install at the same time? Adjustable camber plates, control arms, etc? Thanks in advance! |
11-21-2022, 02:50 PM | #2 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Given the age of the car I would consider the following items
BMW front strut tower reinforcement plates (PN 51717036781) BMW rear coil spring shims (PN 33531094518) Sway Bar End Links (MEY-3160604607HD) Rogue Rear Shock Mounts & reinforcement plate https://www.rogueengineering.com/Rog...air_p_270.html Beyond that it is up to you and the current condition of you car. I also did the control arms, bushings, etc. but mine were TIRED. Good thread to browse https://www.zpost.com/forums/showthr...ighlight=pss10 Last edited by 86Zed; 11-21-2022 at 02:56 PM.. |
11-21-2022, 05:37 PM | #4 | |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Now would be the time to add them since you'll be in there and due for a ride height and alignment/corner balance potentially. Ground Control and H&R have solid options depending on your usage as well. |
11-21-2022, 06:44 PM | #5 |
Rep 45
Cool...thanks for the info. I also plan to run 18x9 rims up front. I try to get everything in advance so I don't have to reinstall things. Thanks for the guidance!
11-23-2022, 03:31 PM | #6 |
Rep 45
11-23-2022, 04:20 PM | #7 | |
Get off my lawn
932
Rep 1,159
Drives: 6MT
12-07-2022, 02:12 AM | #9 |
Rep 45
I got my Vorshlag camber plates. They seem pretty solid. With the round plate on the top, are the reinforcement plates still necessary?
12-07-2022, 07:26 AM | #10 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
The Vorshlag setup is beefier than others. I still installed the reinforcement plates, cheap insurance while you are in there.
01-12-2023, 11:24 PM | #11 |
Rep 45
For the rear coilovers, do the perches sit on top or bottom. I have seen them both ways depending on different brands while doing a google image search. For the Bilstein b16s specifically, should they be on top or bottom?
Thanks |
01-13-2023, 11:18 AM | #12 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
It should sit at the top with the rear coil spring shim (rubber insert) nested in the bottom.
Image from another Z4 forum It may work the other way around but a spanner wrench would be tough to get in there. |
01-14-2023, 08:45 PM | #14 |
Rep 45
Installed! Thanks for the guidance
grannyknot950.50 86Zed932.00 |
