09-23-2020, 09:15 AM | #23 |
Rep 18,756
After the staggared RFT were spent on the E90 long ago, I swapped to GFT (go-flat tires). Knowing the RFT were stiffer sidewalls, I went to a square 18" set up and ran GFT high performance all- season. 245/35-18 XL rated.
One late Christmas Eve, out in West BF Nowhere, where I live, I ran over a block of 2x4. Yep, there was a nail in it. The FTM popped up. Being it was near midnight, very cold, the wife shithammered sitting in the back with the pups, I decided to trek the last 30 miles home rather than try and plug the tire. Next day, I check the pressure, flat as a pancake. Threw the E90 up on the lift to see how bad the leak was. The tire went flat in about 2 minutes, so I drove home on a GFT 30 miles with zero pressure in it. My conclusion from that experience is large diameter, low-profile GFT with XL load rating, are as good as more expensive RFT. Granted it was below 30 degrees, but the tire stayed completely intact. |
09-23-2020, 09:31 AM | #24 | |
Rep 567
As such, neither a spare donut or run flats are in order. Carry a real spare. |
09-23-2020, 10:24 AM | #25 | |
Rep 3,471
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
09-23-2020, 10:26 AM | #26 |
Rep 3,471
The point you missed was that all this time, you are paying more due to the RFT nature of the tires and this is where they "get you" as far as raking in more revenue and profit. It's the gift that keeps on giving to the dealership and tire-shop.
09-23-2020, 10:27 AM | #27 | |
Rep 3,471
09-23-2020, 10:36 AM | #28 | |
Rep 7,484
Thankfully I showed the woman how to swap a wheel out. Even... "you're going on vacation but need all the boot space you can get so you don't want to be carrying a spare tire." The way I see it. A run flat won't save you from a blow out. Even when it's blown out it's no different to a non-rft. There are some great non rft out there. Cheaper and better... The only rft I have ever liked was the Michellin zero pressure. It had all the characteristics of a non-rft but weighed a little more that's all. Michellin have since launched an even better rft that ways the same as a non-rft. I think we're headed to airless tires... hopefully those are out in this lifetime. Then you have the shady garages refusing to repair a rft and insisting once it's gone it's gone. I carry a tire plug kit and tire repair kit (conti mobility kit). |
09-23-2020, 11:53 AM | #29 | |
Rep 2,476
And the point you missed is that I already said I don't buy RFTs, so no one is "getting me". To take that further, a RFT costs more to produce and is heavier resulting in higher shipping costs - this results in a higher cost to the consumer. Where is your data that shows RFTs have a higher profit margin as compared to a non RFT? For the record, I'm not here trying to argue with you. I'm actually interested in knowing more about the subject discussed. |
09-23-2020, 11:58 AM | #30 | |
Rep 18,756
My point is that low aspect ratio tires rated at an XL load capacity are as good or near as good as RFT. Last edited by Efthreeoh; 09-23-2020 at 12:08 PM.. |
09-23-2020, 12:11 PM | #31 |
Rep 1,808
Don't dismiss the 50/50 setup either, it will keep a lot of cruising weight off the low tire in theory anyways. The sway bar would hold it up and the spring would push down... not fun on steering wheels but a tread life saver.
09-23-2020, 12:14 PM | #32 | |
Rep 18,756
They had no problem repairing the tire. |
David701567.00 |
09-23-2020, 01:12 PM | #34 | ||
Rep 7,484
09-23-2020, 02:41 PM | #35 | |
Rep 2,665
Not too long ago I tried to get 2 different large tire stores to patch my wife's Acura tire and both said they wouldn't as the tires were over 5 years old. I took it to an independent and he recommended we get new tires and then fixed it. Within 3 months we replaced all 4 tires (serious doubts it mattered in our climate) but I didn't want to do it that day and thought the liability should have been on us. It's their store and they are welcome to have whatever rules they want to have.
Soul_Glo13352.00 |
09-23-2020, 03:25 PM | #36 | |
Rep 10,358
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
09-23-2020, 03:34 PM | #37 |
drunk poster
6614
Rep 3,649
I enjoy it when they tell you that run flats are "insurance" and then try to sell you the tire replacement package. Yes, so that would be insurance for your insurance.
I just tell them that I'm not medically cleared to drive on runflats because the ride is so harsh it makes me sterile. |
sygazelle11448.50 |
09-23-2020, 04:02 PM | #38 | |
Rep 3,408
I had a beautiful E39 540 with M-tech package and I decided to test drive the brand new F10 when it first came out. (I skipped the fugly E60). I was pulling out of the lot to start the test drive and it felt like was driving Fred Flintstone's car. I had not even driven that F10 200 feet and I wanted to turn around and hand the keys back to them. Having driven 5ers for 20 years at that point, I was just stunned how bad it was. Anyway, I kept the E39 for another couple of years and saved a lot of money doing so. Now, of course, run flat harshness has lessened as the "technology?" improves. But, it's go flats for me. |
09-23-2020, 04:10 PM | #39 | |
Rep 10,358
#1 The speed rating is voided on repaired tires #2 Donuts are single use and therefore must be replaced. #3 Not all tires can be repaired. Consequently a new go flat + new donut spare would cost about the same as one new RFT. Oh and no, you don't need to shave the tread on a replacement tire. That's only applicable to race/track cars. Now obviously in real life people don't replace their donut spare, and will not care about the speed rating on their HP tire because they have those tires for looks anyways.
09-23-2020, 04:58 PM | #40 |
Rep 3,626
lots of fear tactics with cars. crankhubs, run flat, warranties.
I wish warranties were optional. i'd take a 10k discount off a new 911 if it meant no warranty. runflats aren't worth it either, extremely stiff and heavy. |
09-24-2020, 05:47 AM | #41 | |
Rep 18,756
It simply how you approach the SA so he doesn't figure you for some dumb fuck trying to save a few dollars.
09-24-2020, 07:19 AM | #42 | |
Rep 2,665
09-24-2020, 08:56 AM | #43 |
Rep 736
Well, I've learned a lot in this thread. Thx.
Did not realize BMW tuned the suspension to RFTs. And Conventionals will cause the suspension to feel a bit softer I will air up the PS4S on 20 inchers by a few pounds First time I've ever had 20 in wheels and the M Suspension. My Tire Kit in each BMW now consists of KenSun AirCompressor, Tireject Kit, Extra Packet of Tireject, Needle Nose Pliers, Plug, Plug Reemers and Insertion tools, Rubber Cement, Air Gauge. And if all else fails, BMW SOS. I've found that Conventional Tires on 19 and 20 inchers do smooth out the ride immensely, especially on city streets and backroads, which tend to be choppy. They are quieter on the highway. It makes the car liveable for all. I changed on an F10 and had 46k mi on Conventionals. No issues in regular driving.
2017 540i M, Carbon Black/Mocha, 20 in. on Michelin PS4S, CF Mirrors/Rear Spoiler
2009 328i 6 spd stick, Crimson Red/Sport Suspension, Bavsound Stage 1, 2 Former BMWs: '79 320i, '84 325e, 2000 328i, 2014 535i |
09-24-2020, 09:04 AM | #44 | |
Rep 18,756
