      02-20-2014, 09:16 PM   #1
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
F30 M Performance brake kit retrofit
Anyone know of anyone that has retrofitted these to a Z4M or ZCP e46? I'm looking for a cheap way to get some better looking calipers. Not intending to track or needing more breaking power than I already have. Just disappointed in our ugly calipers.
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R|
      02-20-2014, 10:01 PM   #2
F360C
Drives: E86 S54
With a bit of modication to the "p0lar" rear caliper bracket and the rallyroad front bracket you can fit the BoxsterS/Cayman Brembo calipers using your existing ZCP/CSL rotors. At 4 wheel kit can be put together for around $1000-1400 depening on what you get the calipers for.
07 Z4 M Coupe AW/IR
      03-02-2014, 06:54 PM   #3
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
It depends on if you replace rotors or not...that's basically another grand on top...I actually have the whole set up, but about to send out the calipers for powder
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      03-02-2014, 09:54 PM   #4
F360C
Drives: E86 S54
Which rear brackets did you go with?
07 Z4 M Coupe AW/IR
      03-02-2014, 10:07 PM   #5
DRedman45
DRedman45's Avatar
35
I have p0lar's brackets...he is a great sourest for everything to do with this upgrade. I also got all new high temp seals and dust boots from him as well
My Build Thread
      03-02-2014, 10:16 PM   #6
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
What's the best way to contact p0lar?
      03-03-2014, 08:59 PM   #7
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
Probably PM him on m3forum.
06 Alpinweiss Z4M R
Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake
      03-04-2014, 04:39 PM   #8
F360C
Drives: E86 S54
Yeah his brackets are awesome... He is also a great guy to deal with!
The rear bracket does require a bit of grinding to make it fit. Other then that the whole system bolts up as it would on an E46. My brother got a chance to test the system on track one before the season was over and it worked great. More track testing to come this summer.
07 Z4 M Coupe AW/IR
      03-04-2014, 05:34 PM   #9
mtrhed
mtrhed's Avatar
13
I have a set of almost new 928 GTS calipers.... I wonder if they could be made to fit? Hmmm
06 Alpinweiss Z4M R
      03-04-2014, 07:03 PM   #10
DRedman45
DRedman45's Avatar
35
Which area is it that needed to ground down?
My Build Thread
      03-06-2014, 05:08 PM   #11
F360C
Drives: E86 S54
The bolt that connects the upper wishbone to the trailing arm contacts the bracket and it won't fit physically fit on without removal of a fair bit of material. A Dremel tool and some patience solved the problem. p0lar told me when I bought them to let him know how the fit was after I installed them. I got busy over the winter and forgot to shoot him an email. Knowing him once I tell him what's wrong he will have a fully engineered solution to the problem whipped up in an hour.
They sure do look good....
07 Z4 M Coupe AW/IR
