      09-05-2018, 09:13 AM   #1
saintex
Drives: Z4MC BSM E92 335xDrive BSM
Engine start issues
occasionally I am unable to start my car.
Key in and it cranks normally but no light off. Turn off the car and try again and it works normally.
Sometimes it takes 3 attempts before it starts. Always the same symptoms: cranks normally but no ignition, recycle the key and it starts.
Seems like something isn't getting sensed right and the DME won't send either the fuel or the spark.
any ideas?
      09-05-2018, 11:47 AM   #2
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
well I guess the first thing is to check for spark.
then injectors to confirm fuel, gonna need a NOID light for that.
      09-05-2018, 02:31 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Mine's done this very occasionally, like once per year.
Always after filling up with gas. Always starts and runs fine on the second try.
      09-08-2018, 11:31 AM   #4
saintex
It appears to have been an issue with DME EWS alignment due to a battery issue. ISTA was used to realign and so far all is wellNESS
      10-29-2018, 12:38 AM   #5
saintex
Solved
Finally it ended up being this:
https://www.zpost.com/forums/showthread.php?t=716472
The ignition switch failure
      10-29-2018, 09:45 AM   #6
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Yup, been there, done that. Glad you got it sorted mate.
      10-29-2018, 05:34 PM   #7
saintex
Tks bruh. Ya it was becoming irritating and disturbing my ZEN
      10-29-2018, 06:43 PM   #8
saintex
