      05-13-2019, 03:33 PM   #1
mziggy16
Drives: '07 Z4MC, '01 911 C4 Cabriolet
Quick Headlight Question
I have the annoying fast-blinking left turn signal going on, along with the lamp out warning light. After a bit of checking, it looks like it's the parking light that's toast (#5 in the attached image). So, not an "important" light but I'd like to get back to normal turn signal blinks.
Anyway, Real OEM takes me to part #15 in this link
Which, takes me to this part
Instead of spending $35 for the socket assembly, can I just swap out that bulb? If so, is it the bulb from this link (Parking Light Bulb Size: 2825LL)
Thanks!
-Mike
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i
      05-13-2019, 03:43 PM   #2
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Part #15 is for the Halo - the #1 light in your attached picture.
The bulb you want is either #9 or #10 in the RealOEM link
      05-14-2019, 08:33 AM   #3
mziggy16
Helpful - thank you!
      05-14-2019, 10:01 AM   #4
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Use the screwdriver that is supplied in the small tool kit in the trunk to remove and install the assembly that holds the bulb. There seems to be something special about it (a small dimple on it perhaps) that makes removing and installing the bulb assembly easy. Also, there are two of those bulbs per side, may as well change both at the same time.
      05-14-2019, 03:26 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
That's not the parking light. 5 and 6 are both turn signals.
The bulb you want is #9 in the realoem diagram.
#10 bulb is for the parking light. Number 7 in the first post.
      05-15-2019, 10:00 AM   #6
mziggy16
Thanks for all the help!
I pulled out the bulb last night just to be sure and found the culprit.
Time to order the new one.
      05-15-2019, 11:13 PM   #7
pungo
pungo's Avatar
That looks like the halo bulb. I believe the turn signal bulb is orange.
      05-16-2019, 06:28 AM   #8
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
On 2006 and up turn signal bulbs are in white color which is #5 and #6
Angel eyes bulb #1 is same shape as #5 and #6 only difference is AE bulb 21w and turn signal bulb is 10w, also 5 and 6 as well doing parking light job when turn signal is off, for example in Canada its always ON as soon as you start engine
      05-16-2019, 09:45 AM   #9
mziggy16
It was the right bulb - installed last night. #9 in the RealOEM diagram (PN 63217160788), exactly as StickMon described.
      05-16-2019, 06:31 PM   #10
pungo
pungo's Avatar
You're right #5 and #6 are white, I must have been thinking of #7 which is orange.
The AE is a 10w halogen.
