06-16-2019, 09:36 AM | #4 |
Rep 5,995
You have a donor vehicle and the Z4? If you have the tools and ability to DIY it might not caused that much in today's market as they're not worth as much as they used to be.
06-17-2019, 03:21 AM | #6 |
10854
Rep 4,893
The interesting thing is, this car was apparently never build by tuner Manhart...
So quite the error from Top gear who didn't do their homework https://www.zroadster.com/forum/thre...2#post-2460206 This car is the "Hornisse" which at some point was apparently labeled with manhart stickers/bodyart, supposedly when it was with a later owner in switzerland..... Why and who did that is not clear but its strange to say the least, that a tuner (quite a famous one....) claims a build from another person..... There are quite a few reports on the german z forum that it suffers from reliability issues. There's also a guy in the UK that did a s85 swap. The electrical part of the swap is supposedly the most difficult. Integrating the s85 ecu in the rest of the z4 (which is 1 or 2 generations older)
06-17-2019, 05:18 AM | #7 | |
Rep 5,995
07-02-2019, 11:47 AM | #8 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
07-02-2019, 06:25 PM | #9 | |
Rep 1,689
Taken from their website: Function capable S85 engine package for self installation. The engine electronics package has the following properties: Motor control fully OBD, EOBD diagnostic capability DSC disabled Secondary air system disabled Adapted configuration diagnostic ECU network on autonomous use Disabled engine diagnostic probes and function Configuration manual Oil pump fully functional for lateral acceleration Sport button is disabled (can be installed and configured to customer requirements) With this engine package you can take any S85 engine in operation, regardless of where it is installed. Based on the series software, we have developed software that allows the engine no longer has to rely on the complete electrical system. The jumps in all conditions and runs like a train engine. The kit is designed so that it provides you the opportunity to incorporate this in various BMW models and connected to the existing electrical system. The variants are: Software motor control MSS54 Kit MSS54 Kit without control unit MSS54 Kit without Vanos MSS54 Kit without Vanos and without controller Included for variant 2, 3, 4, 5 are included: MSS54 engine control unit with software adaptation Wiring harness for commissioning ECU Installation instructions / switching Plann E-accelerator OBD connector Cooling water outlet temperature sensor Display DGA-RACE-S54 Upgrade Path Custom Sofware -Upgrade opportunities are: Camshaft - Kit Motorsport - Vehicles Further modifications on upon request. http://awron.com/index.php/s85-v10 |
07-03-2019, 04:15 PM | #10 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Pictures and a few videos of the "hornisse" have been floating around for years, always thought it was a cool build.
The challenge is not mounting/fitting the engine in the car, but making it play nice with all the other electronics while maintaining some semblance of OEM feel/functionality. I plan to do the S85 swap and widebody on my car one day, since I'll be keeping it forever.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
07-03-2019, 07:14 PM | #11 |
Rep 911
Definitely cool, but the electronics seems way above even my head. I could never do a swap that involves even more electronic complexity. Seen this car in previous videos, looks like it's just swapping hands and getting cosmetic makeovers now.
Andre - 2J into a Z4 Coupe!
