      05-15-2019, 02:22 PM   #1
txguy1986
Drives: 2004 Z4 E85
Used Airbag deactivate for my small child
I used the Airbag deactivate feature for my small child, now airbag light on dash won't cutoff. I used the keyed cutoff switch next to the passenger door, turned it back on and the light won't turn off now. The airbag light for the passenger seat next to the gear shift seems to work. Are those switches prone to malfunctioning? Any suggestions?
      05-15-2019, 04:05 PM   #2
The HACK
The HACK's Avatar
1821
The passenger airbag wire getting pinched and kinked is a common problem amongst early Z4s. I suspect that's the problem, not the switch.
      05-15-2019, 05:27 PM   #3
txguy1986
Drives: 2004 Z4 E85
Is that something I can get to?
      05-15-2019, 06:26 PM   #4
The HACK
The HACK's Avatar
1821
It’s behind the door somewhere, but I think you should scan the car first to confirm which airbag is not communicating.
      05-16-2019, 09:49 AM   #5
Huz-Z
Huz-Z's Avatar
The occupant sensor mat in the seat base has been known to cause issues and there have recalls on that I think.
      05-16-2019, 01:31 PM   #6
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
The light will stay illuminated until reset, even if you fix the underlying issue. Most generic OBD readers cannot reset the light.
