      02-06-2019, 06:14 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Interest in 355mm Stoptech BBK for nonM Z4?
I'm looking for anyone who is contemplating moving up to a 355mm front BBK from stoptech for you non-M Z4 (or a 330i E46). I've designed a custom bracket and will partner with Zeckhausen Racing to release the brackets for a direct fit. You would purchase a regular Z4M kit, and these brackets separately (or, if you purchase direct from Zeckhausen, they may be swapped for same price as standard kit).
Brackets will be made of same 6061-T6 high strength aluminum, anodized black.
Bracket costs will depend on qty ordered, but if I can get 10 people interested, I can make an order for a fairly good price (expect $100-120 for each bracket, complete with mounting studs). Less than 10, the price will be closer to $200 a bracket.
Please spread the word to any other forum you may know.
      02-07-2019, 07:17 AM   #2
2279
I’d also post on e46fanatics and zhp mafia...
      03-04-2019, 03:45 PM   #3
dre99gsx
UPDATE:
Brackets came in. I installed the hardware and fitment is perfect. This can be done for 380mm on Z4 non-M if needed.
      03-08-2019, 11:02 PM   #4
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
AWESOME!!! Love seeing this kinda stuff.
thanks Andre
Powered by
      03-08-2019, 11:50 PM   #5
dre99gsx
Let me know if you or anyone else is interested! I can have them made to order, ready to install for either kit
One thing to note, my ARC8s hit the caliper on the front. I need about 1.5mm more clearance. I'm not sure anyone has tried Trophy kit on a Z4M with ARC8s? The calipers are centered on the rotor...
Apex SM10s fit without an issue.
      03-25-2019, 11:14 PM   #6
2279
Which Arc-8 (width/offset) are you running in the front?
      03-26-2019, 09:45 PM   #7
dre99gsx
18x9 et30 in the front
      04-06-2019, 11:11 AM   #8
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Purchased tii's stoptech bbk for 3.0si, had to run 5mm bc or rubbing on arc8 et 30 as well
      05-01-2019, 03:49 PM   #9
Eau_Rouge111
Eau_Rouge111's Avatar
Drives: 2009 128i and 2007 Z4M Coupe
UPDATE:
This coming from a fellow machinest...nice work!
      05-01-2019, 03:53 PM   #10
dre99gsx
I'm humbled, thank you!
