      08-18-2018, 05:34 AM   #133
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
Originally Posted by tiltmode43 View Post
Those last HRE shots
So glad I did not get rid of them as they really look great when I am not at the track.
      08-18-2018, 05:54 PM   #134
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
I love your track wheels too. Would have gotten a set if the fitment wasn't so aggressive. But then again, I love my BBS CI-R
      08-21-2018, 04:20 PM   #135
KevsZ4
Drives: 03 Z4 3.0
Saw your car @ C&O a couple weeks ago. Looks even more Beastly in person. Now I just need to figure out which of your mods i can do on my 3.0si.
      08-21-2018, 07:26 PM   #136
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
You should have seen us at the track last weekend, It was so nice to get back behind the wheel again. CCA will be having another event at Road Atlanta at the end of the month.
It was nice to watch the e92 M3's try to keep up.
      11-06-2018, 07:17 PM   #137
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Got to visit the Michelin Proving Grounds and just Finished a weekend at CMP in South Carolina, Next stop Roebling Rd in Savannah in December for Race School.
Mirko182.00
      11-16-2018, 01:42 AM   #138
abelgonzaleZ4
Drives: 2006 BMW Z4 SilvrConvert 3.0i
Originally Posted by M-Cast View Post
Thanks, the car started out as just a daily and has progressed over the years. I did not want the fog lights to be seen, so I put them behind the lower grill.
I ended up finding a piece of Zinc-Plated Slotted Angle and attached it to the subframe. I had to grind down the corners, which I would have made a little cleaner if I did it again.
The lights are 4"LED with a yellow tint and I have a toggle switch on the dash that turns them off and on. They are solid and fit perfectly behind the grill.
Your car looks bad ass!!!!
Love the fog lights behind the grill.
Who makes them? Gotta link?
Ebay?
      11-16-2018, 03:49 AM   #139
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Ebay?
Retro Fit Souce https://www.theretrofitsource.com/
These guys make everything.
      12-26-2018, 10:49 AM   #140
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Gday Will, nice couple of upgrades with the logger/shifter and gauges mate, top notch! I love where your taking this build mate. Awesome!!!
Powered by
      12-26-2018, 11:32 AM   #141
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Thanks, taking the bulkhead down a bit and adding a half cage. I think we can pull 100 to 150 lbs out of the car and still keep it clean on the inside.
      01-14-2019, 02:32 PM   #142
tiltmode43
I plead the 5th.
tiltmode43's Avatar
This build is definitely one of the great N/A builds, I've really enjoyed following it. Is there anything left on the wishlist?
We have evening track days at Road Atlanta and my night vision is not great, so I added them and swapped out all my OEM headlights to LED lamps, I get twice the vision without blinding the guys in front of me.
Do you happen to have any more details on the LED conversion? Or was it also sourced from Retro Fit Souce https://www.theretrofitsource.com/?
-Matt
      01-14-2019, 02:44 PM   #143
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
We have evening track days at Road Atlanta and my night vision is not great, so I added them and [COLOR="Red"]swapped out all my OEM headlights to LED lamps[/COLOR], I get twice the vision without blinding the guys in front of me.
You can try this guy www.retroworkslighting.com he was the actual guy who did my lights retrofit sources provides the components.
I always have new things on my list, going to be upgrading my suspension to a MCS 2 way, adding a half cage and a few other modifications this year. Also started building a spec e46 race car so my plate is full.
      03-04-2019, 11:52 AM   #144
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Back under the knife for the next revision. We had the pull the engine and re ring it, so I have decided to go ahead and jump on a few more things.
* Swapped out the AKG shifter for the RTD
* Widening the front fenders 10mm and the rear 15mm
* New updated diffuser, side and front Splitters
* Adding a half cage.
* taking half the back wall down.
* upgrading to MCS suspension 2 way
* removing the AC
* dropping the cars weight to a targeted 2950 lbs
* adding a carbon roof
I am sure we will make more adjustments as we are moving through this round.
      03-04-2019, 11:48 PM   #145
StickMon
StickMon's Avatar
Drives: 2006 MR
... We had the pull the engine and re ring it ...
Yea, just another day at the office.
Shmeesh. I can't find the wherewithal to pull my dash and replace my heater actuator.
      03-05-2019, 06:55 AM   #146
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Curious, any details on how you plan to widen your fenders? Are you still doing the Spec E46 as well or thinking about doing more with your Coupe?
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      03-05-2019, 12:24 PM   #147
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
We are exploring a couple of options with how much room I need to fit a 275 in the front and a 285 on the rear. It is going in for cage work this weekend, then to the body shop.
I took the e46 to race school a couple of weeks back, and while the Z is out, I am going to start tearing that car down hoping to have it ready by the fall.
      03-05-2019, 03:25 PM   #148
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
You shouldn't need to modify your fenders to fit 275 front and 285 rear. I'm running 275 square. You should also strongly consider running a square setup for track.
      03-05-2019, 03:37 PM   #149
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
What kind of tire and wheel are you running currently?
I run a square set currently, 18x35x265's with no problem, with the current suspension. I have 2 sets one is a 9.5x18 22mm offset and the other is a 10x18 35mm.
      09-06-2019, 12:35 PM   #150
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
g'day Will,
just acquired a set of Dinan high flow TB's. mate, can you clue me in as to what the issues were that you guys were having? id like to know if these things are just plug and play?
Is there a tune that you need to run for these? I read through the Dinan install notes and it talks about some specific limits/tune?
cheers mate. loving the new updates. how wide are you going?
Powered by
