      09-29-2018, 08:58 AM   #1
alex654
Drives: z4m
air ride help??
Hi Everyone im looking to do a bag set up on my z4m. I found a company that does air struts for the car. Just wondering if anyone has bagged a z4m. Just looking for some ideas. any help is appreciated.
      10-22-2018, 03:38 PM   #2
WideEVO
WideEVO's Avatar
Drives: 2003 BMW Z4 Coupe
Not sure what kind of help you're looking for my but my Z4 (non M) is bagged. The only advice I can give you is plan out how you want to run your air line from the front struts.
Example, I have my front air line follow the brake metal line into the engine bay and run both lines into a rubber piece sticking out on the passenger side (behind the glove box), fed it through there and back into the trunk. As far is ignition signal, I used fuse #2 behind the glove box
Always evolving
Arsonism158.00
