      09-20-2020, 06:09 AM   #529
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Hmm, Oem dash has been put in its box, wont be needing that as my race dash arrived (after 5 months.. lol)
You'll also note my new workbench (my mate who got let go (nearly all of my mates got let go) couldent sell his laundry fitout, so I took it over and repurposed it as my work bench)
Comes in at 1.98kgs or 4.3 lbs.
Prob lighter than that in the end as I'll need to trim it to fit.
Pretty stoked with it. Well worth the wait. For those of you with keen eyes, you'll note it's an E30 race dash.. yep.. that's right. Only choice I had was either E36 or E30, the E36 looking super dated.. the e86 race dash came in at nearly 11 times the price of this one as no stock so would have to custom make. Hmm, I'll just grab the E30 one thanks very much..
and then this shit went down... Thx Jesse
Looks like the Vac race box will be up for grabs...
.. after a huge hangover ... Found a huge divot in my slush fund...
.. fark ...!!!
https://www.vividracing.com/ESS-Tuni...151253451.html
File Type: pdf E85 Z4M VT1 & VT2 Installation Manual (1).pdf (5.00 MB, 313 views)
Powered by
wdb4732.00
      09-29-2020, 11:31 PM   #530
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Car is finally at the shop for development and install... Everything..
Powered by
AriuSen776.50
ga4130.50
wdb4732.00
      09-30-2020, 08:24 AM   #531
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Wowie Vanne!!!!
So much to take in - so much progress; you didn't mention that you were keeping your air conditioning and heated seats....ONLY KIDDING!!!!
Such a build....can't wait to see the totalized weight reduction data....it's going to be crazy-light; and then the final weight to horsepower (KW) ratios too.
Will the zebra striped cowboy hat fit in your new race seat??
This is an incredible build.
Racerbruce
      10-01-2020, 01:38 AM   #532
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Lol it had better, or this build is coming to a stop right now..
Boost gauge inbound..
https://www.aemelectronics.com/products/gauges/digital-gauges/boost-display-gauges
Steeler2428.50
wdb4732.00
      10-01-2020, 09:15 AM   #533
Steeler
Steeler's Avatar
2429
This baby is going to be a rocket.
Love it Vanne..
      10-03-2020, 04:47 PM   #534
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks guys.. progress
And last, just a teaser for DTM arms.
pyshin110.50
wdb4732.00
      10-04-2020, 08:28 AM   #535
wdb
dances with roads
wdb's Avatar
4732
That's quite a guibo you have there!
Sachs race clutch?
The flywheel appears to have a replaceable friction surface, I haven't seen that before.
You were definitely due for a new center bearing...
Vanne1620.50
      10-04-2020, 02:31 PM   #536
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Lol yeah guibo.. weird name.. lol
Bit of further stuff...
I woke up late, back from Zurich and headed down to the shop, after dropping the kids off at school and got stuck into the front DTM arms.
Nothing is ever simple..
Strugeled with a part for a while and had to make a sleeve for a bolt as I wasn't happy with how they had designed this particular part of how the bolt was secured.
It's not the circled bolt, I circled that as I think this part is for preventing rotational torque of the mount against the frame, but I can't see how that bit fits together, so before modifying anything I'll ask the DTM kit designer what the purpose of that circled bolt is. It's also possible that this bolt is meant for the E46 M3 as that frame is slightly different at the front. My car will be the first z4m that this kit has been designed for, so there are a couple of changes expected. So far I am very happy with the quality, strength and design of this kit.
Sorry about the large amount of pics, but I need to be sure about any modification made to the kit, to make sure that it will be safe and performs as expeted
The issue with the bolt/insert, I think will be sorted with a slightly larger piece of metal that I'll probably weld in place, thus securing the mount in 3 dimensions. Up, down and lateral.
Powered by
Rekla105.00
wdb4732.00
      10-05-2020, 02:53 PM   #537
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Finally front right finished
That was... Involved..
Powered by
pyshin110.50
wdb4732.00
      10-06-2020, 06:39 AM   #538
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Did MRT get back to you? That side bolt uses a weld-in threaded insert. Those DTM kits put a longitudinal load on the mount location. You need to reinforce that mount location.
Vanne1620.50
      10-06-2020, 06:00 PM   #539
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Michael how about these ones? Recommend? From akg
Instagram: ariusen26
Youtube: Track vids
Vanne1620.50
      10-06-2020, 08:17 PM   #540
Michael9218
595
IMO, the MRT kit is the better kit. I don’t like that the AKG kit puts the inner ball joint and the fcab ball in single sheer (the bolt is not supported on both sides of the bearing). The MRT kit solves this, but does require more fabrication to install (welding). I’m not sure, but it doesn’t look like the AKG kit addresses the longitudinal load at the fcab location.
Vanne1620.50
      10-07-2020, 01:14 PM   #541
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Gday Michael,
Yeah Mikko responded within 3 hours of me emailing him (hes laid up in bed, broken leg), and the contacted me via whatapp. your correct, that mount takes a lateral load, so we welded a huge plate in on the mount and its now secured by 2 bolts (so 4 total) on the side as well and fits completely sung against the frame, so there is no room for any lateral movement. . I thought that would be better and its definitively a much more robust solution.
top marks for MRT's Mikko in working with us to solve any issues. Lucky i have access to a machine shop. There are other bits of the kit we've improved upon, mainly to do with sleeves and colers, but yeah pretty impressed with the kit so far..
I test fitted the front wheels today..... its wide...
long day at the shop...
(while were waiting for the 4 bearings that are being sent to Alex's place
Dropped the diff of at Gear Masters Dubai to get that sorted.
Pulled the airbox/TB's/Oil pump/ oil cooler...
Removed the fuel rail , secondary water pump and a bunch of other crap.
tomorrows task.. carb cleaner.. and clean the whole frikking thing..
if i have time, we might pull the brake master and clutch ..
dead.. going to bed...
Powered by
      10-08-2020, 10:23 AM   #542
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
So I tackled a few things today...
BMW Motorsport thermostat and oil divertor delete.
Removed...
Divertor valve in place.
An10 oil line adaptor in place.
And then this puppy... (Thx Alex!)
Dinan S54 Throttle bodies. 2mm oversize.
This is versus OEM.
Doesn't look like much,but it is.
And then we did this.. still needs a huge cleanup though..
That subframe needs a hellova clean.. add it to the list.
And these are going in the bin..
And bit of surface rust work
Ready for turner monoball bearings.
So even though we did jack shit today, I still did a bit.
Powered by
eggman51198.50
pyshin110.50
wdb4732.00
      10-09-2020, 04:17 AM   #543
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
And then today well.. picture probably speaks for itself.
Powered by
wdb4732.00
      10-13-2020, 08:14 AM   #544
F360C
Drives: E86 S54
Front arms look great! Do your arms increase the steering speed like my SLR arms?
You're going to love those CMP rear subframe bushings...My rear end has never felt so good
07 Z4 M Coupe AW/IR
Vanne1620.50
      10-14-2020, 03:05 PM   #545
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Do you have Ig?
Youtube: Track vids
      10-14-2020, 05:08 PM   #546
Michael9218
595
Are you talking about the lowering subframe bushings?
      10-15-2020, 12:29 AM   #547
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Bit of stuff done..
CSL headers Ceramic coating ... Check..
new position for the oil cooler as the intercooler will go below. New oil coolers plumbed in.
pyshin110.50
wdb4732.00
      10-15-2020, 07:09 AM   #548
F360C
Drives: E86 S54
Originally Posted by AriuSen View Post
Do you have Ig?
I do.... screen name is e86s54
Yes sir... technically these ones raise the subframe closer to the chassis. The raising part might not have done anything and most of what I am feeling might be just from going from rubber to solid bushings. Overall the rear end gives me much clearer information when its on the limit and I can more easily feel where the limit of grip is.
07 Z4 M Coupe AW/IR
      10-15-2020, 01:36 PM   #549
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Part of the kit... Finally building it.
MOEDARE140.00
3GFX722.50
eggman51198.50
      10-16-2020, 07:38 AM   #550
F360C
Drives: E86 S54
The excitement is starting to build! Are you going with ESS for the tune or someone custom?
07 Z4 M Coupe AW/IR
