      02-16-2019, 11:43 AM   #1
JimBob0047
Drives: 2006 Z4MR
Installed today. Had to add some washers to make it work. Y'all think that's ok? I'm running pss10s with Vorshlag camber plates and e46 strut tower reinforcement plates.
      02-17-2019, 05:11 AM   #2
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
Could you really notice any difference with this installed? You didn't mention any perceived performance improvements.
I have been suspicious of their worth on our platform.
      02-17-2019, 06:36 AM   #3
JimBob0047
Drives: 2006 Z4MR
The car definitely felt more planted in the front and steering felt a little sharper. I didn't push as hard as I could because I want to make sure running washers like I did is ok.
My theory is if the M division made a strut bar for the chassis there must of been a legit reason right?
      02-17-2019, 10:39 AM   #4
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
LOL, placebo effect...Especially with the way you have that mounted. Even if this car needed one, yours would do nothing to tame the forces on that strut tower.
BMW did not design the car to use a strut bar. It was available as an accessory due to demand for one. The one BMW made is completely worthless. Flimsy aluminum tubing. I have one and don't run it on my track car. It's just in the way.
If you understand anything about the engineering beauty of triangulation, than you would see that the diagonal strut braces complete a triangle of the fender rail and the firewall. A bent bar running over the motor is not going to effectively prevent the strut towers from flexing outboard under load.
Anyway, nice looking strut bar...
      02-17-2019, 05:28 PM   #5
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
Off topic haha but since you're not using your OEM strut bar, would you like to sell it? Cheers =)
      02-17-2019, 05:30 PM   #6
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
You shouldn't need washers to make it work. Either somethings off or it's poor quality from bmtown...which looks to be the same as mechunik and that sat perfectly flush when I had it on my previous Z.
      02-17-2019, 05:48 PM   #7
JimBob0047
Drives: 2006 Z4MR
I'm running Bilstein pss10 paired with Vorshlag camber plates. The main strut shaft sticks past the strut mounting area just a little requiring the uses of spacers due to the closed deck design of the strut bar mounting plates.
      02-17-2019, 05:49 PM   #8
JimBob0047
Drives: 2006 Z4MR
You mean those hollow flimsy tubes that are prone to fail? 😁
      02-17-2019, 05:56 PM   #9
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
I see, maybe shave it a bit so the shaft clears? That way you'll delete the washers. It's prolly not a biggie but I'd do it, or it'll drive me nuts haha.
