      12-08-2018, 09:02 AM   #1
fun ticket
fun ticket's Avatar
87
Drives: 2017 Ford Raptor
Is refresh rate important for my outdoor TV?
I posted previously for some input on outdoor tv's and got a range of advice from buying expensive outdoor specific TV's to buying cheaper TV's understanding the life span will be short (I'm in Florida; humidity, etc).
I think I am going to go the cheaper route trying to stay $500 or less if I can. Specifics I am looking for are:
1. 45 to 50 inch range
2. Smart TV
3. Samsung or Sony is my preference
4. Refresh Rate (this is my question and reason for my post)
Refresh rate - how big of a deal is this for an outdoor TV that will get minimal use and mostly for football games? I understand it makes a difference if it is your "main" TV for movies, etc and worth paying the price for higher refresh rates. Prices seem to really jump if you go from a 120 rate to 240, etc.
Can I get buy with a 120 rate or will I regret it? Again, factor in the intended use which is minimal, outdoor environment, not the best lighting, etc.
Thanks.
      12-08-2018, 09:23 PM   #2
tony55343
Drives: 08 335i coupe 6mt
I have a 55 120hz and Im happy with it, my girlfriends is a year old Samsung 120hz and her picture looks amazing compared to my vizeo. I think you would be just fine
      12-09-2018, 09:45 AM   #3
Chihuahua
Chihuahua's Avatar
1237
Drives: BMW
It's an outdoor TV. It's a consumable, not an investment. Go cheap, be happy if you get three years out of it. Ask me how I know!! (I'm also in FL). 120hz refresh is more than adequate.
      12-09-2018, 05:53 PM   #4
glennQNYC
Pro V1 Sniper
glennQNYC's Avatar
Drives: M Sport 335i
2014 335i  [4.87]
First you should understand what how refresh rate affects the image. Then you can make an informed decision.
Here is a good explanation of refresh rate: https://www.rtings.com/tv/learn/what...-60hz-vs-120hz
      12-09-2018, 06:32 PM   #5
Darth One
drunk poster
Darth One's Avatar
Drives: M4 GTS | E46 M3
Well that article was....refreshing.
(120hz should be fine...youll just be watching sports and Netflix, no?)
      12-09-2018, 06:43 PM   #6
glennQNYC
Pro V1 Sniper
glennQNYC's Avatar
2014 335i  [4.87]
Sports puts more demands on (is more revealing of) motion artifacts. While not a end-all/be-all, refresh rate is a factor in better motion performance.
      12-09-2018, 06:53 PM   #7
xQx
Australia
716
Drives: 2008 BMW 135i (E88 N54 6AT)
As you can see from the table in the linked article, the maximum refresh rate of your source material is going to be less than 120Hz.
So, I'd say even for your 65" 4K lounge-room TV, you're not going to notice the difference between 120Hz and 240Hz.
If you know what you're looking for, you *might* notice the difference between 60Hz and 120Hz on your outdoor TV; but I'd say 60Hz is sufficient.
2008 BMW 135i Convertible 6AT (E88 N54) M Sport (BMS DCI, VRSF 7" Intercooler, VRSF CP, VRSF v2 DP, Turbosmart BOV, SmartTop Module, xHP Stage 3, BMS Cowl Filters, 2" Inlets & Outlets, MPP TD04/16T Turbos, MFactory 1.5way LSD, Fuel-it Stage 2+ Bucketless)
      12-09-2018, 08:25 PM   #8
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
like mentioned above refresh rate is more for fast moving scenes including sports. so yeah, if you're planning on watching games with this I would look into a TV with a good refresh rate. i'd stick with 120hz or higher would be ideal
~CinnamonLeatherInterior~21"3Piece AlphaForgedWheels~BMSgoldTitaniumLugz~ 3dCarbonRearSpoiler~3dCarbonFrontLip~3dCarbonSideS kirtExtensions~DTMCarbonDiffuser~CarbonWrapPUFront Splitter~CarbonRearSplitters~PUrearDiffuserTray~
~CarbonEmblems~LedermanzWheel~ShadowlineKit~Double SlatGrills~WstyleCarbonRoofSpoiler~CarbonMirrorCov ers~MeisterschaftEVC90mmQuadExhaust~CarbonTipCover s~KWV1Coilovers~MStylePedals~G2GoldCalipers~35%Tin T~
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
