      02-02-2019, 02:28 AM   #1
Wcpp12
Drives: 2008 Z4M
Looking to buy this. Am I asking for something that's impossible to find?
      02-02-2019, 06:53 AM   #2
2286
Pretty much but even if you did it appears the bar uses a hinge design anyway so you could do better IMO
      02-02-2019, 06:55 AM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
If it doesn't have to be Dinan per se, you could look at strongstrut, which is still for sale I believe:
http://www.strong-strut.com/Z4/front...20strut/Z4.htm
And arguably better (stiffer?, lighter?)
      02-02-2019, 11:25 AM   #4
VindieselJetta
Drives: Z4m
Been wanting that for a few years, but can’t quite justify $400. I already have Strong firewall braces.
      02-04-2019, 02:08 PM   #5
mrGcoupe
mr G
mrGcoupe's Avatar
Drives: 2007 BMW Z4MC
you could try this one instead as it is very similar to whats in ur picture from cosmos racing; https://www.cosmoracing.com/
      02-04-2019, 06:14 PM   #6
JimBob0047
Drives: 2006 Z4MR
If you have aftermarket suspension/camber plates and your main center strut bolt/adjustment knob sticks past your strut mounting area then the only strut bars that will work are the OEM(very rare) and the Turner motorsports one(takes about two months to receive). The mounting plate on the strut bar has to have an open center design to allow for clearance.
      02-11-2019, 11:58 PM   #7
Z4M E85
Drives: BMW Z4M Roadster
Thank you so much! I am just about to buy a new strut bar. Cuz after I upgrade an aftermarket suspension, the old was no longer fit with it. Any suggestions besides OEM and Tuner motorsports?
