10-21-2013, 11:23 PM | #1 |
Rep 231
Brake pedal travel
The last couple track days my brake pedal has seemed to have a little extra travel. I've bleed the brakes between events and it hasn't seem to help. Did some searching on the forums but haven't found anything. No sign of leaking, pads are fine, rotors are fine. Brakes seem to stop fine but the pedal is down a couple engines which makes heel toe almost impossible. I read another post about someone having to replace their master cylinder but I don't want to jump to conclusions. Any advice at what I should look at next?
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
10-22-2013, 01:06 PM | #3 |
Rep 231
ATE Blue. This morning I get in to go to work and the pedal goes almost to the floor. Two pumps and it is back to normal all the way to work.
10-22-2013, 01:20 PM | #4 |
Rep 96
How old is the fluid? Brake fluid even if it is in the bottle and never used will go bad unless sealed.
Why dont you just try a full flush with fresh fluid first?
Currently Driving:
Porsche GT4 '20 BMW M2C '19 Caterham S3 '01 Porsche 993 '96 |
10-22-2013, 01:31 PM | #5 |
enthusiast
48
Rep 1,695
10-22-2013, 01:54 PM | #6 |
Rep 4,531
How are you bleeding the system?
If you are pumping the pedal, and doing a 2-man job you can easily ruin the master cylinder seal if you do it incorrectly |
10-22-2013, 02:19 PM | #7 | |
Rep 11,667
I'm not sure i follow you. do you mean the possibility of moving sediment etc into the seals if you bottom it out too far?
10-22-2013, 06:18 PM | #8 |
Rep 4,531
10-22-2013, 09:00 PM | #9 |
Rep 231
Using the Motive power bleeder.
10-22-2013, 09:02 PM | #10 |
Rep 231
I may just try another full flush with new fluid and see how it feels.
10-24-2013, 09:02 AM | #11 | |
Rep 12,565
I personally am no longer a fan of ATE blue, sure it's cheap but it stains the reservoirs and can reach boiling point pretty easily. For a few bucks more I buy RBF 600 or PFC RH 665. |
10-24-2013, 09:30 AM | #12 |
Rep 11,667
^+1 on the fluid
10-24-2013, 09:44 AM | #13 |
1821
Rep 5,337
How much pad is left?
10-24-2013, 01:49 PM | #14 |
Rep 231
About 50% pad left.
10-24-2013, 02:19 PM | #15 | |
Rep 376
Mods: OEM Euro Headers, RPI Scoop Daily: 2010 Tacoma Double Cab |
10-24-2013, 10:16 PM | #16 |
enthusiast
48
Rep 1,695
10-25-2013, 12:42 AM | #17 |
636
Rep 3,124
I'm sometimes wrong, but this sounds like master cylinder failure.
I've had them fail on 2 Chevy trucks and 1 Toyota, and that was pretty much the symptom.
10-25-2013, 09:47 AM | #18 |
salty cowboys fan
6158
Rep 3,406
There has to be a leak somewhere. Fluids don't compress; if you aren't able to maintain hydraulic pressure via the pedal, the fluid has to be going somewhere. As others stated, master cylinder is a good place to start looking if you aren't seeing brake fluid on the ground.
Edit - this is assuming the system is bled of course |
10-25-2013, 12:11 PM | #19 | |
Rep 1,373
How are you liking the PFC fluid? I think that is what i am going to use next as I am only hearing great things about it and it isn't as expensive as the liguid gold Castrol SRF.
07 Z4 M Coupe AW/IR Last edited by F360C; 10-29-2013 at 10:47 PM.. |
10-25-2013, 12:19 PM | #20 | |
Rep 12,565
Second time was NJMP Lightning, probably had 6 days since it was last bled, and I was running Motul 600 then. PFC was good, never had fade but over the years I've learned not to go on an entire season (about 12 days for me) without at least bleeding the brakes once or twice in between. So that means I do a full flush beginning of season which is around March and then bleed once in June and once in Sept. If I feel like I've been especially hard on the brakes, I may just do another flush mid-season. I've hear from buddies that run Castrol they can go an entire year or two w/o bleeding them and they never encountered fade lol. |
10-25-2013, 03:15 PM | #21 |
Rep 376
10-25-2013, 04:30 PM | #22 |
1821
Rep 5,337
There you go.
This seems to be the primary reason to go with fixed calipers, since based on my experience, the pad wear makes little to no appreciable difference in a fixed caliper, multi-piston unit because the fluid is distributed over 4-6 times the number of tiny pistons rather than a HUGE one. So as the pad wears down, pedal travel increases. Especially for track use, the larger single piston means more fluid volume is getting compressed over a spread out pad surface, resulting in what feels like further pedal travel, and as you brake hard for track use, flex in pad over the single pivot resulting in further feel of softness in pedal travel. Typically, I ditch my track pads when they get down below 35% of pad left because on the stock sliding calipers, it gets increasingly difficult to get a good sense of how much braking you still have due to the increased vagueness of the pedal travel.
