08-06-2013, 01:10 PM | #1 |
Rep 1,107
Z4M Front Brake Caliper Bolt Torque
I've got a varying rubbing, sometimes screeching noise coming from my front passenger side wheel and need to take a look tonight. Has anybody got quick access to the torque specs for the 7mm bolts? I want to take the pads out of the equation and spin the rotor free to do a quick check of what's what. It may be a bearing (which I don't feel like changing) but I want to make sure first. Thx.
08-06-2013, 01:11 PM | #2 |
1821
Rep 5,337
30Nm, ~25 ft*lbs.
08-06-2013, 10:16 PM | #3 |
Rep 1,107
Thanks. Bearing is fine. Some debris (e.g. small piece of edge of one pad) dropped out when I pulled off the piston/pads so that may have been it. I cleaned and greased up the pins and slapped it back together. Sounded fine on a quick 10 minute run to get ice cream. We'll see what comes.
08-06-2013, 10:42 PM | #4 |
1821
Rep 5,337
You shouldn't grease the pins.
08-07-2013, 09:12 AM | #6 |
Certified Adrenaline Junkie
43
Rep 1,325
I greased my pins and I got grease all down the side of my car after a good rain. Was a pain to clean off. Curious why not to grease BMW Pins also. Have always greased pins on other cars. Is this wrong for all cars or just BMWs?
08-07-2013, 09:39 AM | #7 | |
Rep 11,667
No grease, because dust and dirt become embedded and then its an abrasive that will score the pins and jamb them up.
08-07-2013, 10:20 AM | #8 |
Rep 1,107
I've been reading up on the other Bimmer forums and many folks including full time mechanics believe the "no grease" edict is because BMW is fearful people wont use the proper lubricant and will end up swelling (can that be used as a verb?) the bushings. Many mechanics say they have been lightly using sylicone based pin lube (Sylglide).
08-07-2013, 10:28 AM | #9 |
1821
Rep 5,337
BMW specifically said no grease in their TIS repair procedures. You're free to do what you want, of course, but the pins are designed not to require grease...Hence the rubber sleeves.
If it was a brass bushing the pins are sliding on, then yes I'd grease it.
08-07-2013, 10:32 AM | #10 |
Rep 1,107
What are the bushings made of? (and what are the pin/bushing materials commonly used in applications where a lubricant is recommended). Just trying to learn something (not be a wise ass).
08-07-2013, 10:38 AM | #11 |
1821
Rep 5,337
OE bushings are simple rubber I believe. You would only use lubricant if it's metal on metal, like a brass bushing kit.
