07-20-2012, 01:48 PM | #1 |
Rep 1,663
KW V3 Rear Coils Rubbing
It looks like my rear KW V3 coils are rubbing themselves. I've double checked the bump/rebound settings (set them at the values recommended by KW), and as you can see my ride height is extremely conservative. This is all street driving.
I've sent these pictures to KW to see what their opinion is. My concern is that with the paint rubbing off that my coils will rust.
07-20-2012, 02:18 PM | #2 | |
Rep 1,663
Here's what I got back from KW:
I guess I can always do the swift linear spring conversion for the rear...
07-20-2012, 02:21 PM | #3 | |
Rep 1,135
that aside, it is common for springs to sit on top of each other like that (progressive i mean). if i were you id just get some coil wrap like KW suggested. no harm will come of it (the spring coils sitting on each other). eventually the noise will go away as they continue to sit on each other. |
07-20-2012, 02:22 PM | #4 |
1821
Rep 5,337
mixing and matching springs should only be attempted if you really know what you're doing, IMO. If you're going to swap to linear Swift springs in the rear, I would HIGHLY recommend you swap out the front too, especially if the fronts are progressive rates as well.
if you don't want to do that, KW's solution is 99% valid. I'd treat the exposed springs to some anti-rusting spray first though. But do keep in mind, eventually the coil wrap or the tubing is going to get worn away as well.
07-21-2012, 02:38 PM | #6 |
Rep 1,663
Sorry I should've mentioned, the original reason I wrote KW was because I was getting groaning noise from the rear. I thought it might have been the rear shock mounts, but turns out it was just the coils binding.
So I guess it's normal and I should just not worry about it. I do want to do the swift spring conversion at some point at all 4 corners like Hack suggests, but right now other mods (and unexpected expenses like kitty vet bills) are going to push it out.
