07-19-2012, 11:47 PM | #1 |
Rep 32
H&R Anti-Roll Bar?
Hi All,
I'm thinking about getting these H&R roll bars, anyone have any experience with these? Any other suggestions? Thank You in advance! http://www.tirerack.com/suspension/s...4&autoModClar= |
07-20-2012, 12:33 AM | #2 |
enthusiast
48
Rep 1,695
There are 2 companies making anti-rollbars that I know of:
- h and r is making everyones (even when they are calling them there own) - and ground control Most everyone I believe is runnung h and r, probably because they are close to half the price of GC's. I think GC's are the best for the most adjustability but not worth the price for most. |
07-20-2012, 06:41 AM | #3 |
Rep 4,531
I'm pretty sure you can fit a OEM Z4M Bar on your car. Someone did it before on this forum. I know that for a fact.
I can sell you mine if you want (27mm front), and it will be alot cheaper than that |
07-20-2012, 10:23 AM | #4 | |
Rep 12,565
07-20-2012, 03:28 PM | #5 | |
Rep 815
FWIW I have H&R bars front and rear and am more or less happy with them. Fronts give 90% of the reduction in body roll. Adding in the rear just dials out the mild understeer that installing the front creates. The front is a pretty easy install. The rear is a bit more of a pain threading that big hunk of metal through the narrow nooks and crannies. IMO for street driving just installing the front bar is sufficient. If you're Autoxing, need your car to be neutral (and your class regs allow it) then go for the rear bar too. Some of the experienced track guys around here will tell you that anti-roll bars are the last thing you should monkey with on your suspension (shocks, springs, tires and alignment first). They're probably right, but throwing on a big front bar is reasonably easy and cheap and really does make the car feel a lot less wallowy in turns. |
