01-28-2012, 01:24 AM | #1 |
Rep 503
Drives: Z4 M Coupe
355mm 6piston Stoptechs behind stock wheels?
Hi guys! Anyone's tried to install the Stoptech kit with stock wheels? Just bought a used kit and i was wondering if i can get them to fit behind our stock M wheels.
01-28-2012, 01:18 PM | #2 |
Rep 5,327
no problem..... they'll fit fine :-) you may need to add a spacer but im pretty certain you wont need to do that either......
enjoy matey
01-28-2012, 03:14 PM | #3 | |
Rep 503
Drives: Z4 M Coupe
I'm probably in the minority here but i actually really like our stock M wheels and i wouldnt want to have to swap to something else.
01-29-2012, 03:50 PM | #4 |
Rep 5,327
our front offsets kinda suck, drop ST an email.... they'll tell you for sure..... im going to guess this kit is designed to fit under the stock rims........ but ive never seen anyone actually run a BBK with the stock wheels.... goodluck, your going to be blown away with your new braking performance...
01-29-2012, 03:54 PM | #5 | |
Rep 503
Drives: Z4 M Coupe
Was on the track today and while the brakes held up fine for the 1 session i did(Motul 660 fluid) i just wish for not having to worry about them getting soft at all by the end of a track day. Hoping these babies will do the trick.
01-29-2012, 04:31 PM | #6 | |
Rep 5,327
01-30-2012, 12:05 PM | #8 |
Rep 5,327
ohh no ga, not good, hopefully you'll check with the diagram and all will be well!!
01-30-2012, 12:30 PM | #9 |
Rep 503
Drives: Z4 M Coupe
Since they're coming either way I'll just try them on as is. Maybe they'll fit with just a relocation of the wheel weights or something. If not I have a friend who'll give me his spacers.
08-14-2012, 02:44 AM | #10 |
Rep 700
So what ended up happening?
Did they fit? Any pictures of the finished install?
08-14-2012, 02:49 AM | #11 |
Rep 503
Drives: Z4 M Coupe
With 12.5mm spacers from Turner Motorsport they do indeed fit, albeit very tightly.
My front tires rub though with that set up, they're Yokohama AD08's in stock Z4M sizes. These are the only pictures i have of them so far:
08-14-2012, 03:48 AM | #12 |
Rep 700
Very nice.
Yes, I thought the front would be the problem area as there is very little room even on a stock set-up. I really have to get organised and buy myself some TMS Wheel Studs and a set of KICS Nuts.
