08-03-2012, 11:50 AM | #1 |
Rep 65
Lowering on KW V3's
Does anyone know if I will need to run spacers on the front wheels with the KW V3 setup?
This would be on a Z4MC with the stock wheels. On KW's site it mentions "Wheel spacers may be necessary if using stock tires." |
08-03-2012, 12:28 PM | #2 |
Rep 1,031
I am on the highest setting in the front and have no issue with stock wheels, no spacer. Not sure if I lowered it, have never tried. I am running camber plates set to the middle setting so that might be the reason, not likely but another variable in the mix.
08-03-2012, 12:49 PM | #3 |
Rep 65
Mirko - Thanks for the info. My guess is that since the springs get progressively wider towards the top, that it might become an issue if you lower the car too much. I don't imagine that the camber plates would have an effect but then again..maybe.
How does the ride height with the KW's in their highest setting compare to stock height? Did you notice any difference? |
08-03-2012, 05:52 PM | #4 |
Rep 1,031
The front is tucked in a little bit, I'd say that 1/2" to 1" and the back is a set a little lower than stock (you can actually go higher than stock in the back).
The other z4m is stock and I am lowered. |
