      05-21-2017, 08:49 AM   #199
03z4
Drives: 2003 z4 2.5
Originally Posted by XMetal View Post
I believed what "3002tii" meant was your new tires will be:
Front sidewall height: 225mm x 35% = 78.75mm
Rear sidewall height: 255mm x 35% = 89.25mm
So the rears on your new setup WILL be "taller" than the fronts
Your previous setup are actually much closer matched with the rears just slightly more "taller":
Front sidewall height: 225mm x 40% = 90.00mm
Rear sidewall height: 265mm x 35% = 92.75mm
This equation gives a direct tire to tire comparison but makes no provision for the effect wheel width has on final height. I'm not saying my setup will end up better, I'll measure once mounted and confirm what the end result is.
      05-22-2017, 06:02 AM   #200
03z4
Drives: 2003 z4 2.5
225 / 8.5 = 26.47 (mm of tire width per inch of wheel width)
26.47 x 9.5 = 251.47. So the rear tire will be 3.5mm larger tire width total, as it relates to the wheel width ratio vs the front 8.5.
      02-23-2018, 06:30 PM   #201
HTM101
Drives: 2007 Z4 Coupe
Installed New Wheels Today
I've had the car a month, and it looked like this.
Today I replaced the factory wheels with:
Apex EC-7 8.5 x 18, ET35 with Michelin Pilot SS 235/40
Apex EC-7 9.5 x 18, ET35 with Michelin Pilot SS 265/35
      09-11-2018, 03:11 PM   #202
Chadio12
Drives: '07 E85 Z4 3.0si
Had my '07 3.0si for a few years now but I decided on CCW classics with a black satin center and stepped lip (18 x 8.5 front and 18 x 9.5 rear). Maybe not for everyone but I love the look!
      09-11-2018, 06:16 PM   #203
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Not a fan of the blacked out headlights and corner markers, but man those CCW's are looking hot!! Great choice, I'm loving your wheel choice, it makes me want to go multi-piece.
-Matt
      09-12-2018, 09:01 AM   #204
Chadio12
Thank you!
Truth is I preferred to have the inside of the light blacked out rather than the film. Thankfully it's reversible. I'm looking for a shop that can open it up, black it out and give me a brighter bulb for the halo.
      09-12-2018, 09:08 AM   #205
Chadio12
Originally Posted by M-Power M3 View Post
18x8.5 et38 + spacers =
18x8.5 et24 f
18x8.5 et13 r
What kid of lights are those? I have been looking for a quality set that have black backing just like that. I'm afraid of the ones I see online that could be of cheap quality. Looks really good. Much better than tinting the lens like I did.
      10-09-2018, 08:08 AM   #206
r4gs
Viper Driver
Singapore
36
Drives: F-16
Smile BBS LM-Rs
It has been absolute ages since i've posted here on zpost, but i am absolutely thrilled with how these new shoes look on the zed and thought to share.
Genuine BBS LM-Rs - brushed, stepped lip with diamond black centers
F 19x8.5et28 with 245/35R19 Michelin PS4S
R 19x9.5et35 with 12mm spacers and 275/30R19 Michelin PS4S
Lowered quite a bit on KWV3s; slight rub on the front liner at the joint between front bumper and fender and will raise the ride height about 10mm all around to increase the clearance. Surprisingly comfortable and compliant ride coming from 18s!
3798j11325.00
HTM10157.00
      10-09-2018, 01:46 PM   #207
Carter
Carter's Avatar
England
32
Drives: Z4m coupe
Went gold
      03-21-2019, 12:09 AM   #208
doane2u
Drives: 2012 135i M Sport E88
Powder coated OEM wheels
HTM10157.00
      12-22-2020, 08:00 AM   #209
c41250n
c41250n's Avatar
Hong Kong
30
Drives: BMW Z4M Coupe
BBS LM
19x9.5 +20 225/35/19
19x11 +18 265/30/19
      12-22-2020, 02:42 PM   #210
kyriian
kyriian's Avatar
884
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
Volk OG TE37
18x9.5 +28 with a 3mm spacer
18x10.5 +30 with a 12mm spacer
Revolution of our Times
I will return to the track, one day.
      12-28-2020, 10:35 AM   #211
///A D O L F O
Drives: 2003 BMW Z4 (e85) 3.0i
Hello, ZPOST!
Wheels: Konig Hypergram (17x9 et35)
Tires: Hankook Ventus Evo 2 (255/40/17)
Suspension: Megan Racing Euro II (coilovers)
      10-19-2022, 01:21 AM   #212
Landiko10
Drives: Z4 2008 Coupe
Rims
What are your thoughts about the 313 wheels?
